Engine Limp Mode
wes06dmax
Feb 23, 2009
1,367
South Central Kentucky
Why is it in limp mode? What codes did it throw?
I have had mine apart and just put it back together
All of the codes that are throwed are normal for me all but the P0621, P0622 and I cant figure out why my betterys will not charge I am 99% i hooked up the alternator right I mean there is only 1 connector that will fit it right
Here is the codes
P0045 T/S Charger Boost Ctrl Solenoid Circ/Open
P0107 MAP/Baro Pres Circ Lo Input
P0113 Intake Air Temp Circ Hi Input
P0405 Exhaust Gas Recirculation SensorA Circ Lo
P0532 A/C Refrigerant Pres Sensor Circ Lo Input
P0540 Manifold Intake Air Heater Circ
P0621 Generator Lamp L Ctrl Circ Error
P0622 Generator Field F Ctrl Circ Error
P2564 Turbocharger Boost Ctrl Pos Sensor Circ Low
ChevyTruckGuy78
Twins done Now for trans
Feb 7, 2010
694
Ct.
i had a turbo code and had teh same issues of limp mode i would be climbing hills towing and get an overboost code and bam limp mode
wes06dmax
Feb 23, 2009
1,367
Does anybody else have any ideas I have retuned the truck, cleared the codes hooked up the rest of the sensors all but the turbo ones and it is still in limp mode I never had the trouble before
wes06dmax
Feb 23, 2009
1,367
Did you turn the codes off see what it does ? An did you check fuses shit like that
I checked all the fuses they are good, I have turned the key on cleared the codes and then cranked it that didnt work either I even cleared them going down the rd, I have a buddy that works at a car dealership and he is gonna see if he can bring home a tech 2 tomarrow
wes06dmax
Feb 23, 2009
1,367
Well today I cranked it up took some engine bright sprayed all over the engine, sprayed the engine off, shut the hood, give the rest of the truck a lick and a promise and it is fine, I havnt done anything different, I didnt clear any codes or reflash it, maybe it just wanted a bath lol these trucks are moody just like a woman
