Is it possible for banks of cylinders to have different EGT temperatures.?
I installed a probe in each exhaust manifold, after the install one side was running on the highway 700 degrees, the other 1200 degrees. I found that I had kinked the probe cable in the gauge pod enough to create resistance undid the kink now I have an equal 700 degrees while cruising. On hard acceleration the temperatures vary widely sometimes in the 350 degree range and when at a stop light one side is -200 the other is ~350.
Not possible. You have other issues.
What type, please do elaborate.? Have you used two EGT probes.?
http://www.duramaxdiesels.com/forum/showthread.php?t=67655
