drop shackle questions
Parker_
I'm a torque addict !!
May 13, 2014
244
Blythe ca
I have the same shackles and I know a few people including myself that run the bolts opposite of factory . No issues
baddaddition
Mar 10, 2013
287
Pm flyin Elvis his truck we did two yrs. Ago and sets really nice!
Sent from my XT1254 using Tapatalk
flyinelvis11
543
49
VG, IL (because my wife does)
Late to the party as usual.....lol
As you well know the only way to make these gold trucks look good is to mod the crap out of them.... 3" rear drop and keys turned way out
4,967
A little info for those that dont know how to figure out how much the shackle will lower their truck when it has multiple holes.
If you want the shackle to lower the back of the truck 1", it will take a 2" longer shackle than stock to achieve it. Think of the springs as a lever with the fulcrum point at the front where the spring bolts to the frame hanger. the axle is exactly half way back from that fulcrum point while the shackle is at the very end. to move the axle any amount, the shackle must move twice as much.
so to get 3" of drop, it will take a 6" longer shackle than stock. I can say ive seen a few drop shackles that dont measure out to what they claim and you can see it in the drop they give. specifically the "1-2 drop shackles" i have on my truck. measured them out and at the top hole, i showed i should only get 1" of drop and no more. put them on where i measured and they were exactly that. granted these were the cheapest ones i could find on ebay so im not surprised.
melms23
253
WI
I agree. My eBay 3" shackles achieved a 2" drop. Even with the shackles and overload removed, the truck is not low in the rear by any means.
Still has a good amount of rake with the t-bar bolts removed.
fastpunker
adrenaline junkie
Feb 7, 2012
215
Lake Havasu City, AZ
Glad you hit on that James, I'm a little surprised nobody else chimed in on that also. Are our rear leafs a 50/50 ratio for the axle pin? (I can't remember atm, I know my Tacoma factory leafs are more of a 40/60 ratio)
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
As you lower via shackles the pinion is also pointed downward the further you drop. Depending on your truck you may or not acquire a driveline vibration.
4,967
yup, ours are 50/50. toyota and jeep did weird 70/30, 60/40 ratios on some rigs. XJs use a really off set pin
4,967
Not based on the front being the fulcrum, draw a picture of the leaf spring and strike a line though the leaf spring ends and raise the rear one it points the pinion downward
your right, im thinking of lifting it.
i have usually suggested people grab a pair of 3* shims for the rear end when they use a 3" drop shackle. more than 3" of drop starts to get into a very long shackle (ass end can become unstable) and very bad pinion angle
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
I had a thought you might be getting high, oh wait, lifting it...:rofl:
Now for the other part of the drop, the thickest part of the shim is to the back to adjust the pinion back up, I believe that is correct...
motoking_1990
1,950
Terre Haute, IN
What are these shims you speak of?
4,967
^^ yes but be careful. Some of these shims don't come with a pin in them to keep the leaf pack centered. You may need to put a longer center pin in with a spacer between it and the leaf pack so the pin can sit in the hole of the axle
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
thanks for the good info. Thats what I was wondering in the first place. I've atually come to be pretty happy with how it sits. I measured a buddies stock truck and his space from tire to wheel well was 10 inches and mine is 8 so im happy. It looks taller in the picture.
motoking_1990
1,950
Terre Haute, IN
So the shims is thicker on one end to tilt the axle one way or another? Interesting. I'm new to this whole lowering thing. The question is how much angle is too much and causes problems?
4,967
It's quite a bit of text for me to put up again but the short of it is, you want the downward angle of the tcase output or Trans output to be the same as the upward angle of the pinion. You want to be within a few degrees of either. Then you select your shim and install
