So I installed some drop shackles in the rig last night. Not totally happy with how it sits. Its not quite as low as I feel it should be. I do have air bags and they have 5 PSI in them so maybe thats why, but I have about 8 inches between my tires and wheel well. I'm also wondering what harm is running the shackle bolts the way I have in the picture? I'm assuming the factory installs them the other way so they cannot fall out. would they ever come loose and fall out? I cannot get them in without dropping the leafs all of the way down so I installed them backwards. I have the shackles in the hole that measures 7.5 inches CTC of the bolt holes. Factory was 4.5, so I assume that is the "3 inch drop" setting?
