How easily do the downpipes come out of our trucks? Do you have to put them on a lift, remove the turbo, etc., or will they come out without too much hassle?
Thanks!
Thanks!
It helps if you pull the transmission dipstick. Might even be a requirement; it's been a long time since I pulled the stock downpipe.
x3 thats what i did.X2 I used to just undo the 2 nuts and push it back against the firewall.
may have to pull the trans dipstick too
Nope, no lift needed. Hardest part is getting to the v-band at the back of the turbo. Once you get the GPCM out of the way the install is a breeze.
No need to take the GPCM off, I have done several without removing it. Its a little tough to get the v band off with it in the way, but then again its harder to get the gpcm bracket off.
Paul FWIW the LMM imo it is better to remove the GPCM
Is the LMM really any different than the LBZ?
