Do a good deed with your computer.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
thanks guys I was doing this on my own tell I had to wipe my laptop due to illness. So I was just wanted my points to go to the site. Though I know it is not all about the points...
Chevmeister
Big Dooley
Dec 3, 2010
281
Garnet Valley, Pa
Nope its all about the WUs!!!
Really, think about it, each WU could be the one step they need. The points and all is just a way to get the competitive people like us to get the job done. The coolest thing is the fact that you and I, average schmucks are helping really smart people find the cause or even a cure to a disease.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Looking through " Terminal " -tail of the process for folding on the linux box I came across this. Also, I fixed the unknown argument, I had a fat finger in there. :D
Anyone have any ideads? 10 percent is an hour saved if it's repairable.
Writing final coordinates.
Average load imbalance: 35.4 %
Part of the total run time spent waiting due to load imbalance: 9.5 %
Steps where the load balancing was limited by -rdd, -rcon and/or -dds: X 0 % Y 0 %
NOTE: 9.5 % performance was lost due to load imbalance
in the domain decomposition.
Parallel run - timing based on wallclock.
NODE (s) Real (s) (%)
Time: 45063.000 45063.000 100.0
12h31:03
(Mnbf/s) (GFlops) (ns/day) (hour/ns)
Performance: 135.117 8.737 1.917 12.517
Thanx for Using GROMACS - Have a Nice Day
[18:41:33] DynamicWrapper: Finished Work Unit: sleep=10000
[18:41:43]
[18:41:43] Finished Work Unit:
[18:41:43] - Reading up to 3697632 from "work/wudata_01.trr": Read 3697632
[18:41:43] trr file hash check passed.
[18:41:43] edr file hash check passed.
[18:41:43] logfile size: 58818
[18:41:43] Leaving Run
[18:41:45] - Writing 3792002 bytes of core data to disk...
[18:41:46] ... Done.
[18:41:46] - Shutting down core
[18:41:46]
[18:41:46] Folding@home Core Shutdown: FINISHED_UNIT
[18:41:48] CoreStatus = 64 (100)
[18:41:48] Sending work to server
[18:41:48] Project: 6063 (Run 0, Clone 8, Gen 261)
[18:41:48] + Attempting to send results [December 31 18:41:48 UTC]
[18:42:47] + Results successfully sent
[18:42:47] Thank you for your contribution to Folding@Home.
[18:42:47] + Starting local stats count at 1
Warning: Ignoring unknown arg
[18:42:51] - Preparing to get new work unit...
[18:42:51] Cleaning up work directory
[18:42:51] + Attempting to get work packet
[18:42:51] Passkey found
[18:42:51] - Connecting to assignment server
[18:42:52] - Successful: assigned to (171.64.65.54).
[18:42:52] + News From Folding@Home: Welcome to Folding@Home
[18:42:52] Loaded queue successfully.
[18:43:00] + Closed connections
[18:43:00]
[18:43:00] + Processing work unit
[18:43:00] Core required: FahCore_a3.exe
[18:43:00] Core found.
[18:43:00] Working on queue slot 02 [December 31 18:43:00 UTC]
[18:43:00] + Working ...
[18:43:00]
[18:43:00] *------------------------------*
[18:43:00] Folding@Home Gromacs SMP Core
[18:43:00] Version 2.22 (Mar 12, 2010)
[18:43:00]
[18:43:00] Preparing to commence simulation
[18:43:00] - Looking at optimizations...
[18:43:00] - Created dyn
[18:43:00] - Files status OK
[18:43:00] - Expanded 1765007 -> 2254429 (decompressed 127.7 percent)
[18:43:00] Called DecompressByteArray: compressed_data_size=1765007 data_size=2254429, decompressed_data_size=2254429 diff=0
[18:43:00] - Digital signature verified
[18:43:00]
[18:43:00] Project: 6062 (Run 0, Clone 73, Gen 250)
[18:43:00]
[18:43:00] Assembly optimizations on if available.
[18:43:00] Entering M.D.
Reading file work/wudata_02.tpr, VERSION 4.0.99_development_20090605 (single precision)
Starting 16 threads
Edit * found it. http://foldingforum.org/viewtopic.php?f=44&t=13324
C.C.Reed
May 1, 2008
91
Are the new GPU WUs more stable? My main rig has been running over 48 hours straight and not dropped down in PPD. Usually after about 12 hours, one of the two cards will drop to half. It happens more quickly if I raise the overclock.
Rob, have your cards quit dropping off?
Poltergeist
Ghost in the Machine
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
My are more stable. But I also removed my PCIe extender cables. The cards are very close to each other but I have a 140mm fan sitting right on top of them for cooling (besides the ones behind them). I don't know if removing the cables did it or they did something to WUs.
C.C.Reed
May 1, 2008
91
Well. . . I found some deals and ended up pulling the trigger on a multi-processor build. I probably should've waited but, hell it's only money. It's a quad Socket F and I really wanted to find a quad Socket G34 but it'll have 24 cores and do EVERYTHING I need to do.
Code:
1 - Tyan S4985
4 - Opteron 8431 2.4GHz 6 core
4 - Kingston 2 x KVR800D2E5K2/4G
1 - Mushkin MKNPS1200-A 1200w PSU
I only have $600 in it now with just the RAM to buy. I am ordering it this week when I get around to it. I should have a loaded rig for just over a grand which is a great deal considering TigerDirect sells the board I got for just under a grand.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4605535
:thumb:
Also, if anyone is looking to pick up a SR-2 rig for cheap. There is one for sale on [H]ardForum.
Code:
SR2 dual L5640 rig
2x L5640 processors
6x 1Gb DIMMS
SilverStone Strider Plus 1KW power supply
>$2000
That's $3000 worth of parts not including the RAM.
http://hardforum.com/showthread.php?t=1582297
I've already wasted all I need to. . . or. . . there's always tax return money.
:angel:
niteflite1287
Now with 3 antennas
May 30, 2010
New London, CT
i'm now pretending i didn't see that last post.... must save for for trans rebuild and not throw a grad or two at a new system for the hell of it. (read that as wanting a build a dedicated folding machine)
1,755
bump
is anyone on here still folding?
just looked through the list and looks like no one has folded in the last 7 days but me
hmm, sandbagging maybe? or is this just dead?:confused:
3,682
236
I quit last summer (or was it the summer before?) when my computer started heating up my room too bad. Kept meaning to start it back up, but ended up getting into video encoding, and that keeps the thing busy now.
I wonder if they would care if I had my work PC folding after hours? :spit: That thing is a beast. :woott:
1,755
well i've managed to move myself into 4th place after about three years of crunching. looks like at this pace it will be around 55 years to top C.C.Reed :roflmao:
