Haven't see a good camshaft thread in a while if at all...
Anyone have the specs on the current OEM camshafts?
Duration @.006", @.050" lift, LSA, intake centline
Lb7, LLY, LBZ, LMM, LML?
Going from a LMM .040 17.5:1 long block to bone stock LBZ long block.
The LBZ block spools faster, runs cleaner, and RPM power band is 3-400rpm lower.. With 8ci less displacement, lower compression. In sure some of the difference is piston bowl related... Piston bowl design does not move rpm band around.... Camshafts depict rpm range. And everything else plays off that, heads, turbo, etc
It's "supposed" to be same at the LMM yet it doesn't perform the same even when it had stock pistons...
I see alot of LSA in the 109° range Hamilton/comp/crane. Socal won't release their specs.. Is TTS still making camshafts?
While narrow LSA are beneficial to increase efficency in upper rpm usage mainly because one can use savaging to help pull more air into a cylinder... Mainly noticeable on SC/NA engines..
My basic understanding of LSA
Narrow LSA of 106-110° kill efficiency in lower rpms and excell at higher rpm where as LSA of 112-116° or wide LSA increase efficiency in lower rpm and run out of steam at higher rpm..
Educated deductive reasoning. Turbo charged engine would be hurt from narrow LSA due to exhaust back pressures seriously reduce scavenging.. When one Looks up turbo spec'd camshaft and compare them to a SC/NA Camshaft of same rpm range the turbo charge camshaft have a wider LSA
I'd degree my LMM but I don't have a 1piece crankshaft
