Cam gears
jpowel29
780
Bentonville, Arkansas
LBZ has the two piece cam gear and the older engines have a regular one piece gear.
Any other differences between the gears? Can a LB7 cam gear be used in a LBZ? Are the crank drive gears the same that would allow the cam gears to interchange?
9,903
149
The new style is a pain in the ass lol will cut you fast also.
Hmmmnnn, it's been so long since I pulled my shortblock down I don't even remember what they look like. All I know is it's going back in whatever it is LOL!
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
On the lbz kind your supposed to remove one of the 6 bolts and put it in the other hole on it before removing the others. That will hold it at the proper tension. If you don't do that it will spin and cause confusion. Besides that its really nothing special
Dave c
Jul 7, 2013
294
Just pull that spring out and back together, dont need to buy another gear. Unless you just want less parts to mess with.
