Boost leak test- hot side pipe ID?
Dozerboy
4,815
396
TX of course
That pvc is well rated for that pressure. Standard pvc pipe is rated at 300psi.
It's not that the PCV is going to fail nessarly, but if it slips out since it's ment to be glued. The clamp doesn't have anything to bite on to or a rolled bead.
oscyjack
May 7, 2016
775
Northeast
Awesome info, thanks guys. I'm going to try the PVC route first, hopefully it works well enough. Can't wait to see where the leaks are and get this puppy running right.
A boost test on a duramax would also reveal exhaust leaks in the engine bay correct?
3,683
236
No, the stock cam has 0 overlap, so there isn't any possibility of having both an intake and exhaust valve open at the same time to pressurize the exhaust. Plus, it would just blow out the tailpipe.
Odds are you will have one or more cylinders with the intake valves open, so you can see how much boost leaks past the rings. On my stock motor, it was basically 0 (couldn't hear or feel any air coming out the PCV or oil fill). With my built motor with loose rings (on purpose), I can hear some air blow past the rings, but can't feel it coming out anywhere.
To check for exhaust leaks, you'd basically do the reverse of this, and pressurize the exhaust from the tailpipe. Not sure what you would use to seal to the end of the exhaust, though.
Awenta
4,090
CT
Use a bigger expandable pvc plug. Should take less pressure than the intake side
N2BRK
1,907
233
I clamped the crap out of it and used my compressor's regulator. You could kiss or add another regulator etc. it's solid rubber and holds on great, and allows you to clamp down like mad.
jelweldr177
Jul 10, 2016
24
Badass ingenuity man!
Sent from my SM-G930V using Tapatalk
