Biggest twin setup and tow
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
Ive been reading till my eyes are crossed and I still cant decide what way to go.
34' bumper pull behind 07 suburban and possibly pull a second trailer behind the 34 or Baja. Engine mods done rods pistons pumps and stuffs. So far im torn between the 483 and 488 with stock charger in valley for a minute. later a danville in the valley or sxe369 gated. talking to some Ive run the idea of gating around exhaust and the cold side of the lil turbo. Whats some thoughts for MAX power and still tow for the Atmo and its exhaust side and style. Wehrli tossed out SXE369 and S488. Annnnnd Go :cool:
sickdiesel
Apr 22, 2010
1,019
id personally do something like the danville stg2R in the valley with an 83 OR start with the SXE369 then twin over that later so you arent having to re-do the piping..
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
CNTRY. I dont have that part yet so thems be open. So the 83 is the way to go? Isnt the 83 a billet wheel? I know the 88 is. If I do the 83 I could most likey do the 369 now too. the 83 is a t4 housing 120.25 flows 130 lbs a min.
Thnk you for the guidence. keep it flowing :thumb:
Edit: Im looking at a 369sxe with a dodge housing already gated. Id just need to fab or buy a pedistal
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I think if you plan on spending any amount of time with the trailers behind the truck a 69/88 setup will be too big. Yes it will be fast but have fun trying to control EGTs.
Chad006
Drag racer wannabe
Feb 12, 2015
311
5
Goodlow, B.C.
With my new build I'll be running a 68mm 3794 and a billet 480 and spraying it until I meet my horsepower goals. Best of both worlds as far as I'm concerned.
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
Soo stock over 83 sounds to be the trick. Ill use the egr port for the gate valve.
Also have stg 2 afe socal cam if that helps or hurts
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
"stock" won't be very fun. That 83 will be way to much charger to run with a stock turbo. I also wouldn;t use a stock set of uppipes with an egr port for a high horsepower setup.
moparkxracer
2,309
33
Out and about
I had a 66/83 is a very fun setup. Pulled forever, loved that setup. Someone here is selling a 483. If you are swapping out the valley turbo, I'd look into something other then the 300 series. Just my opinion.
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
Its an lbz on lmm electronics. Yea I need to build up pipes for sho. Just to healp out I do own a Lincon 275 tig (not that I can weld for shit) 14k probably be bout right. Ill have to use N2o for the rest of my power goals.
monster50iii
329
I'd go with either a 3794 or 4094 stg2r from Danville in the valley. You're going to want to stay vgt in the valley for spool to help keep the egts down. My buddies 4094stg2r runs warmer than my 3794 towing fyi
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
Doesnt Danville mod the stock vvt? and if need gate around the lil ****er when the big one lights. Looking at the 480 sxe it flows upwards 130 the 483 sx only flows 120. the 83 is 3mm bigger and i would guess it spools slower because of inertia? do i get a custom built 85 billet 480sx w race cover? http://www.stainlessdiesel.com/index.php?route=product/product&path=83&product_id=329
Thanks for the info folks im greatful to have it :thumb:
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
It is an excellent charger:D. Although I'm not sure I'd want to tow with it. I'm no turbo expert but just seems to big, if towing performance is any concern.
