Question: Battery relocation.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Well I'm bringing this back from the dead as I am going to relocate my batteries but was thinking of putting them behind the back seat or in the back where the spare tire goes.
I would consider the frame rail like the LML dual batteries. Does anyone have a GM part number on them?
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Are you looking for the battery tray part number for the frame rail? I wound up just making my own bracket and mounting mine behind the bumper.
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
Mounted on driver rail on the inside to protect it and all stock cables were still utilized.
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
The part number for the one most are using with twins is GM PART # 15041310. It's on gmpartsdirect.com for $41.
Utahski
Oct 20, 2008
546
Northern Utah
Where Nathan puts them under the pass. seat, on the outside of the frame, is actually pretty good. The bottom is visible but access to the cables is tricky and you have to use just the right wrench. The mount bolts aren't so easy either. It's not easy to mess with.
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Thanks! Works out well for me. When I had the stock bumper I could reach jumper cables right in through the front holes, but with the bumpers I made I'm using Warn quick connects (one front and rear) for the jumper cables, an inverter, and one of these days a winch. Here's some pics with the old bumper than one with the new one.
mackthehack
DUH...
Apr 16, 2007
831
Looks good! So does that Sam Adams... I might have to copy your design and check the access with the gmc bumper.
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
You're welcome to it! I just made a new positive lead from the power block on the left side of the motor to the new location. And the Sam Adams is mandatory for these projects. :) As long as you stay under that radiator support it shouldn't interfere with the bumper. I'd also suggest something on the inside of the bracket bottom to keep the batteries from rubbing through on the metal.:thumb:
mackthehack
DUH...
Apr 16, 2007
831
:thumb:
