Another Aussie doing a lbz into a patrol conversion :)
Bosvelk
May 5, 2013
Ok, got any instructions on that one? I might need to leave it on for the emissions crap when I go to get it all licences properly... As I think I need to match the emmsions out put of the silverado because a newer engine in older car etc...
Or won't a tail pipe test show up that the EGR system has been removed?
antwon88
Jul 18, 2014
62
i know of 2 and mines in w.a and registered with no EGR crap :thumb: also the one in the pic above has no EGR gear fitted
as for instructions pull all the EGR gear off bin it and weld a plate over the hole where it use to feed out off the up pipes (the things going into the turbo from each exhaust manifold) haha or make new up pipes which is what we normally do
Bosvelk
May 5, 2013
Did all that :) what did you do with the water feed coming from the thermostat housing to the egr cooler?
Bosvelk
May 5, 2013
Now to order some simple bits and pieces,
Like 3 inch high flow Y bridge
A non pinched exhaust manifold
Pcv re route kit
Etc
Ordered my oil cooler, trans cooler and intercooler
DirtyJ
Dec 7, 2014
14
Didn't realise these run an engine oil cooler...
Which Y bridge you gonna run?
Where you getting the coolers from?
What are you doing with the radiator?
Happy New Year mate. Looking forward to the more powerful 2015.
Sent from somewhere I wish I wasn't.
Bosvelk
May 5, 2013
Yep they have a coolant feed oil cooler which we need to remove to clear chassis I'm prty sure...
Gona run heaths y bridge has a very fair priced one!
Coolers etc ordered on line,
Yet to decide on radiator... Not sure if factory one can handle it... Still need to research that one.
Bosvelk
May 5, 2013
Engine is in place between the chassis!,very very tight fit :/
Bosvelk
May 5, 2013
Nop... But lots of beating to fire wall to get exhaust to fit down rear of fire wall
Bosvelk
May 5, 2013
Alright,
Need to know a few things from you guys,
Oil type for my trans
2007,
And amount to do a full refill, not just a change
Bosvelk
May 5, 2013
So it is totally finished!
And all licensed and pitted :)
And I have 470hp 1160nm at the rear wheels
Does the 1/4 mile in 12.9
