2007 LBZ 6 mpg in town
Raines Iron Works
Apr 25, 2017
15
Hello I'm new to the Duramax family. I have a 2007 lbz with 107k miles
Bone stock with factory size tires. I just checked my mileage for the first time, the dash said 13.8 but actually it was 6.3 driving like a grandpa for the most part.
What's wrong with my truck?
Thanks in advance
1,605
Welcome to the site, but I have to ask why you arent taking the truck to a shop to have it checked out?
Theres no way to know whats going on with the truck with so little info and no history. Its best to be diagnosed in person.
Raines Iron Works
Apr 25, 2017
15
I would take it to the shop but I work close to 70 hours a week right now so I have not had the time. I just bought the truck a few weeks ago. From what I can tell it was a grandpa truck before with a 5th wheel hitch.
I just ordered the EGR blocker and finger stick hoping that will help
All fluid changes and filters are current. I'm not sure what can be going on.
Raines Iron Works
Apr 25, 2017
15
I don't think so ChrisPerry. It has been a constant 1/4 tank a day on my 26 mile commute. I have a 59 F100 with a pi$$ed off 300" straight six and it does better than my modern diesel. The only thing I can think is a EGR malfunction or plugged cat but it has not thrown a CEL and it has plenty of power.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Look for fuel leaks. I'm north of 400HP to the wheels with mine, and couldn't get MPG that bad if I tried. My WORST tank has been 10.2, and that was towing a box trailer that weighed close to 10K and stood almost 12 feet tall, running 70+ GETTIN ON IT! Otherwise you're going to have to give us something to go on here. And I HIGHLY doubt even a stuck open EGR valve would drop the MPG's that much without MASSIVE amounts of black smoke and running like crap.
ChrisPerry
Apr 4, 2016
209
Ventura, CA
I'm with Ferm here. I got 12.5-13 towing 10k at 75 with a hung open egr that cause a steady haze from the exhaust. I'd think at 6 mpg you would be rolling smoke everywhere you went.
Raines Iron Works
Apr 25, 2017
15
Just a quick update. I finally got a few minutes today between job 1 and job 2 to roll under my new to me truck. No fuel leaks anywhere, in fact the only leak is the rear output seal on the T case. I'm still stumped
The exhaust is clean until I mash the pedal and no haze at idle. I guess it's time for the shop . Is anyone on here from around Folsom California
I need a good mechanic recommendation
Thanks in advance
Tothemax
xgmtech
Oct 16, 2014
607
new york
you differently have something going on. I have two 06 lbz trucks. my dually is heavy over 8500#s with 33'' tires and tuned and pulls down 13mpg and my crew cab short bed with bigger turbo and injectors drives around on a 700hp tune and still gets 14mpg
greendury
Jan 28, 2011
130
Last three tanks through my 07 lbz have all fell between 16 and 17 MPG. Truck is bone stock.
a8nistor
Mar 28, 2017
5
Folsom, ?!! GO TO Orangevale Diesel. Local Diesel pros for sure. I'm from Auburn, CA. Just half hour from you
Sent from my LG-H901 using Tapatalk
1,741
Thanks in advance
Im in folsom, pm me. I have a v2 and can get some logs to post up for every to see.
I wouldnt take it to orangevale diesel, rude poeple in my oppion. I would go to Folsom Diesel Works on Sibley
Hambone
Always learning
Jan 24, 2016
572
Florida
Just some personal experience
I have an Ac compressor going bad on mine right now and I've noticed about a 1-2mpg drop because of it...
not saying it's your problem but you definitely should look at all your pulleys and make sure non are binding up
a8nistor
Mar 28, 2017
5
Well, always a different opinion.
