and heres what I did.
gmc502 Member Jan 16, 2011 463 12 18 Apr 19, 2014 #21 and heres what I did. Attachments ficm3.JPG 122.1 KB · Views: 37 ficm.JPG 104.9 KB · Views: 33 ficm4.JPG 122.8 KB · Views: 34 ficm1.JPG 121.4 KB · Views: 36
RPM Motorsports smokinum May 13, 2008 3,271 10 38 Central Valley Ca. Apr 19, 2014 #22 Looks good, I've used that area as well. I prefer the threaded hole that is at an angle with the valve cover. It gives it a cleaner look.
gmc502 Member Jan 16, 2011 463 12 18 Apr 19, 2014 #23 RPM Motorsports said: Looks good, I've used that area as well. I prefer the threaded hole that is at an angle with the valve cover. It gives it a cleaner look. Click to expand... you have a pic of it on the angled mounts?
gmc502 Member Jan 16, 2011 463 12 18 Apr 20, 2014 #24 now that the harness is cleaned up,,looks pretty good now.plus when its in the truck,I'll see the injectors and valve cover on that side. Attachments ficm9.JPG 136.6 KB · Views: 35
F Flattire5978 New member Oct 25, 2023 1 0 1 Arkansas Oct 25, 2023 #25 Josh2002cc said: Is this what you need? If you want these emailed to you or need another diagram, let me know. Josh Click to expand... Are the 02 03 bail connections the same?
