2002 and 2003 LB7: Engine harness bail connector diagram?
gmc502
463
12
I have a 2002 lb7 and was given a 2003 lb7 engine harness.wanting to see what the difference is betw the 2.then I have to switch the injector ends over to 2005 lly injector ends.
thanks in advance.
clrussell
pro-procrastinator
Sep 23, 2013
5,906
363
Need a connector view of the main engine harness connectors for a 02 and an 03 right? If that's what ya need I can get that for ya.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Is this what you need?
If you want these emailed to you or need another diagram, let me know.
Josh
Josh2002cc
That Uncle
Apr 2, 2007
1,832
clrussell
pro-procrastinator
Sep 23, 2013
5,906
363
Did you get the connector views you needed? I can't email them for some reason but I can take a picture of the screen if you still need them
gmc502
463
12
I could use the bail connector pin out of the 02 and 05.
when people splice these connector,,are you cutting and soldering or removing the the pins?
I need to replace the bail connectors on the 05,,their damaged.
clrussell
pro-procrastinator
Sep 23, 2013
5,906
363
Theese are off the 05
Larger connector
Hopefully that's what you needed. If you need me to email you those pictures I can.
If the pins are the same design I would pull one pin at a time and move to the connector you need it in, I wouldnt splice that many wires. That's just asking for problems
gmc502
463
12
ok,after less than gentle handling,,I found out that the tan cover on the c108 connector comes off.extraction of the pins were done w/ a modified(thinned down) small screw driver.
thanks everyone,the melding of the 02 and 05 harness is basically done.
now just need to tape it up.
gmc502
463
12
thought I'd give you guys some pics of what I'm building.
gmc502
463
12
couple more and again,thanks guys for your help.low 12's here I come.
clrussell
pro-procrastinator
Sep 23, 2013
5,906
363
Hmmm I like your intake design.. Might have to steal that idea after we get everything mocked up.
gmc502
463
12
On another front,,how is everyone thats done this swap,mounting the ficm?I have an idea using the 02/03 bracket.just looking for other ideas.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
If your re locating the filter head.. I mount the FICM about 2" above the valve cover, using the extra threaded holes in the valve cover in that area. There is a spacer/stud on the lb7 fuel dist block, that works perfect if used upside down. Thread the stud side into the valve cover, and use a bolt through the FICM mount to the stud. I've never had an issue running the FICM dry, even in the stock location.
gmc502
463
12
sound good,do you happen to have a pic?
gmc502
463
12
no pic needed now.I took your advise and put it where the fuel filter use to sit or there abouts.
pics tomorrow as I am painting the chopped up ficm bracket that was modded.
