100% Over injector Issue
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I ran my truck at the track a couple weeks ago. Truck currently has a s476, Dual Fuelers, and 100% over injectors. Maintained rail pressure and low pressure great. Ran cleaner then stock. Weighed in at 6100 with me in it. The time sheet is with Korys tunes 2500 pulse. After talking with Kory that fallowing week he though maybe my injectors where only 30% overs. So I pulled one and had it tested locally. The local company said it was only a 37% over injector. Now the company I bought them from says they are 100%. What are your guys opinion on this?
paint94979
Beer Nazi
Sep 18, 2006
11,714
On 2500uS with 100% overs you should be running pretty dirty down the track... My guess is they are 30% over
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I went a good bit faster than you on my 30's, dual pumps, single s472 on 2450us weighing 6900lbs. 12.0@113
whatever you have absolutey are no where near 100% overs. I'd be pissed.
Burn Down
Sep 14, 2008
7,093
Boise Idaho
Are they calling them 100hp over instead of 100%? Sounds like some one has the terminology messed up... IIRC II 30% are considered 100HP.
Awenta
4,090
CT
Where are these from? I'm wary of places that rate injectors in hp instead of %.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Invoice show 100% overs. We are trying to figure it out. The math of my track times show 525-550hp. Witch seems about right for 35ish over injectors at that pulse. My dsp5 switch is working just fine. I checked it with the lap top
Burn Down
Sep 14, 2008
7,093
Boise Idaho
What have they had to say about it?
clrussell
pro-procrastinator
Sep 23, 2013
5,906
363
After I had the one tested I called them. He had me pull all of them all and send them back. Today he called and said they tested 100% over. So now I don't know what to do.
Get your money back and go somewhere else..
clrussell
pro-procrastinator
Sep 23, 2013
5,906
363
I also wonder if you get them back if they are magically 100%s now
Burn Down
Sep 14, 2008
7,093
Boise Idaho
Who tested them? And who's tips are they? I don't want to purchase something that is false/mis advertised...
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
They was tested locally at Diesel Specialties on a bosch test bench in Nebraska. I am not going to say any names cause I want to make sure that the injectors are actually not 100 overs. As of right now I told them to send them back to me. Then I will send them out to another place to get a 3rd opinion. Just wanted everyone's thoughts on the test sheet and time slip.
CaptPhil
1,012
Delaware
It is one thing to get injectors that are bigger than advertised, but those are obviously way smaller than they are supposed to be. 2500us on true 100's will be over 1k hp with enough turbo. Local guy at the track has 100's and a single 475 and was trapping 122mph in a pulling truck on a 2300us tune.
paint94979
Beer Nazi
Sep 18, 2006
11,714
dude they are not 100% overs not even close... IIRC at similar weight Matts triple turbo truck ran 10.3 on 2900uS on 45% overs. Hell I ran 115 mph at 6700 lbs on similar air with a 3300uS tune. You need to send them elsewhere IMHO...
