Anyone have a FICM wiring schematic for an 05 LLY? I have one coming that is bowing the fuse for the EDU as soon as the key is turned on. fixed the rub issue a week ago on the alt bracket and there was a wire rubbed through on that and causing a miss. so last night I put a fuse in and as soon as the key is turned on it blows the fuse. so I unhooked the ficm connectors and still blows the fuse immediately. I plan on checking continuity from the harness side of the fuse to ground and moving the harness around but would like to know what wire in the harness supplies power to the FICM. Or what else it supplies power to.
He said he went to pull out of his driveway and it just shut off an that was it. never started again.
