How many teeth on our cam gear?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
Norco CA
www.mcratracing.com
I forgot, and don't remember where I wrote it.
A CP3 pump has a 7.5mm bore x 7.5mm stroke x 3 cylinders. This is 331 mm3 potential. If it is not a "progressive" pump, that's about 1000mm3 per revolution.
Or my math sucks.
304
shit i dont have mine near by me.... but got a crankshaft gear ;)
crank gear has 42 teeth on it since the cam spins 1/2 the crank speed meen the cam gear would be 84 teeth
hope that help with the math pat :hug:
304
oops i missed a tooth on the crank gear :damnit:
nar
iirc cylinder volume can be calucalted by
bore x bore x stroke x.7854 = 1 cylinder or 331.34mm
7.5 x 7.5 x 7.5 x .7854= 331.34mm3 per cylinder
331mm3 x 3 cylinders = 993mm3
classification of the CP3 pump is a positive fixed displacement pump.... am i reading that right pat?
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
I get 316.40625 mm3 of volume per revolution of the CP3 shaft. ((3.14)(R*R)7.5) =316.40625 ??????
You must divide the 7.5mm of bore / 2 to get the radius.. Then square the radius.. then mulitply by 3.142, then by 7.5 for the height of the cylinder.
Then multiply by 3 for the number of cylinders or plungers.
See below examples.
Brayden
Jan 16, 2008
1,170
1000mm3 is 1 liter... I doubt that it can displace a "Big Slam" of Mt. Dew every revolution. You can substitute a "liter of cola" also...
Hehe.. Super troopers.. Shenanigans... Liter-o-cola.
Ok I'll shutup now.
304
See below examples.
i got 331.38 per cylinder with you formula....with all 3 piston you are looking at just shy of a 1000mm or one liter
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
Norco CA
www.mcratracing.com
nar
Yes, I took one apart yesterday out of curiousity.
It's a normal radial piston engine design without a con rod, 2 stroke.
duramaximizer
#1 Abuse Enabler ;)
May 4, 2008
1,187
Edgerton, Ohio
So how is the CP3 geared in relationship to the cam.
BTW I took one all apart, I am thinking about a BBK for it LMAO.
But it's still apart, I will probably loose the pieces before I get it put back together. ;)
Brayden
Jan 16, 2008
1,170
CP3 turns at cam speed... 1/2 of crank.... Although the CP3 drive gear is a bit smaller than the cam gear IIRC, so that would be overdriving it somewhat.. but not enough to get back to crank speed.
