I'm nearing 100k miles on the LLY here and am just wondering what chassis parts to inspect/replace.
I am still on OEM everything. Wheel bearings, pitman/idler, brake pads, all hoses, etc.
I know the service intervals on all of the fluids, I'm talking hard parts here.
i know, i know!!!!! tighten the damn front diff bolt/bracket!!
:spit:
seriously, jsut a normal good check over is what id do. check all front end parts for wear (steering and suspension), pull the rear drive shaft and check the u-joints (if you really wanna get into it), check all your fluids level wise and if they need replacement, check battery cables/ends for corrosion, check air filter, check cabin filter (if you have one), check radiator/condensor/intercooler for blockages, check all lights, check brakes, check tires for unusual wear, grease all greasable joints, and im sure some other little stuff im forgettin.
oh yeah, change your spark plugs :woott:
