My abs light comes on, the service brake system comes on the DIC, chimes go off, Parking brake light is on, truck stalls and will not restart? What could cause this? Truck is lifted and has 33.8" tires speedo corrected by Efi live. I recently uninstalled a ppe boost controller and and edge juice. When I flash efi live tunes I have ECM communication issues and have to flash on slow speed. Truck has some rust so bad grounds are possible or maybe just some wires chafing? Help!
Diagnostic Trouble Codes
P0880 "TCM Power Input Signal" PHC ($18) "Transmission Control Module (TCM)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($1A) "Transfer Case Shift Control Module (TCSCM)"
U1024 "Lost Communications With Transmission Controller - Device $18" H ($1A) "Transfer Case Shift Control Module (TCSCM)"
U1000 "Class 2 Data Link" H ($1A) "Transfer Case Shift Control Module (TCSCM)"
C0055 "Rear Wheel Speed Sensor (both wheels) Circuit" MH ($29) "Electronic Brake Control Module (EBCM)"
B2615 "Passenger Compartment Dimming 2 (courtesy lamps etc.) Circuit" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
U1000 "Class 2 Data Link" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
U1024 "Lost Communications With Transmission Controller - Device $18" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
B0024 "Right Front/Passenger Knee Deployment Loop" HC ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
U1000 "Class 2 Data Link" H ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($60) "Instrument Panel Cluster (IPC)"
U1024 "Lost Communications With Transmission Controller - Device $18" H ($60) "Instrument Panel Cluster (IPC)"
U1000 "Class 2 Data Link" H ($60) "Instrument Panel Cluster (IPC)"
U1000 "Class 2 Data Link" H ($80) "Radio (RAD)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($80) "Radio (RAD)"
B0229 "Recirculate Position Feedback Circuit Range/Performance" HC ($98) "HVAC Control Module"
U1000 "Class 2 Data Link" H ($98) "HVAC Control Module"
U1016 "Lost Communications With Engine Controller - Device $10" H ($98) "HVAC Control Module"
U1016 "Lost Communications With Engine Controller - Device $10" H ($A0) "Driver Door Module (DDM)"
U1024 "Lost Communications With Transmission Controller - Device $18" H ($A0) "Driver Door Module (DDM)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($A1) "Front Passenger Door Module (FPDM)"
History data
History data
