Best rearend setup?
wikdlmm
<-- OWFA
Jun 27, 2008
1,974
san angelo
We are leaving the factory suspension in our 02. What I want to know is what spring setup is the best? 2 or 3 leafs? We only have the overload taken out...
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
Im running 3 right now without bags. You could run 2 but I would use bags and add some traction bars, im sure the wrap will be crazy.
Subman
Old Geezer
Jun 27, 2008
3,233
10
79
Madras, OR, Pahrump NV
invest in some QAI double adjustable shocks, both front and back, absolute best thing you can do for your truck, add cal tracks and still clamp the front of your rear springs for good measure, at least till you see how it handles.:thumb:
13,599
633
With your truck being 2wd I'd think you would want as soft a spring rate you can get. You'll probably need to put your caltracs on it to fight axle wrap. Like Ken said, get some QA1s, but you'll be setting them different from the 4wd guys. You want the front to come up so the weight will transfer to the back tires. You could probably get by with just the front shocks, but you will probably want double adjustables.
13,599
633
I'd say go with 2. If it doesn't work well, put the 3rd one back in and see what that does for you.
13,599
633
I pulled all but the two longest springs, added Cal-Tracs, and 3-way adjustable drag shocks.
Adjustable compression, adjustable rebound, what's the third? I've never heard of 3 way adjustable shocks.
13,599
633
Since we're on the subject, anyone ever tried anything like this? They've gotta be a lot lighter than the stock springs, and you could get any spring rate you want.
jpowel29
780
Bentonville, Arkansas
The rear shocks are single adjustable (both comp/rebound). I am trying the old school Competition Engineering that are called 3-way adjustable (50/50/ 60/40, and 70/30). It is actually just 3 valving settings.
