OK most of you know I am a hot rodder which is why Pat & Kat asked me to help with the site. But I am a Diesel noob. So here is the question:
What is a complete list of everything that is needed to transplant a Duramax and get it running correctly into say: a 69 C10. If we can get a good list I'll make this a sticky.
Obvious is:
1. Motor
2. ECM & wiring harness for motor
3. TCM, Transmission & wiring harness (if wanting to use a modern trans)
4. Reprogramming of the ECM so it will run in an older truck/car/boat
5. intercooler/plumbing
6. Fuel Injected fuel system: Baffled fuel tank, pump and lines
7. Throttle pedal and sensors
8. Motor mounts
9. ??
Obvious is:
1. Motor
8. Motor mounts
9. ??
