neither in Michigan. but i know Cali, Nevada, and New York (I believe) require one
they will require one in 2010
knowing this stupid state it wouldn't surprise me
how do you guys get past it? i know that just putting the converter back on isnt gonna be an instant cure...
for me stock tune and passed with flying colors . but i am not required to have cat , my state only does a optic test to measure the particulate ( soot ) .
So even a truck with so many mods such as yours could pass !? Wow, so If I delete my dpf and then get a PPE all I would have to do is set the tuner for stock and I would pass!? :rofl: I hope they don't check for DPF's/Cats every time...
on a opacity test yes ( optic levels of soot ) , remember none of any of our mods except for egr deletes, cats removed and dpf's removed , will effect a emission test... other than larger injectors and such, but even those could be tuned back to a stock amount of fuel . more fuel is about all that will fail you and that is a strictly "tune" addition . larger and more turbo's will actually burn cleaner on stock tuning .
and i dont know if thats what the 2010 will be or if it actually sniffs it and measures nox and such . and i garentee you they will check for cats and dpf's ,the fine for shops not checking are huge and the health dept.'s have dummy under cover vehicles the send out all the time to test shops cheating . i work for the government as a mechanic , lead tech for salt lake county , and have set up cars to fail on purpose on these test cars . i am not a diesel specialist and have not kept track of the changes happening though . our heavy truck shop does all of our diesel work . my 01 is looking better all the time .
I would imagine. They smogged my 02 here in Vegas 8 months ago, but they do the same here as they do where Trent is. Drive the truck on the rollers, run the truck up to 40mph or so and check what comes out.Are they going to smoge all year d-maxs in ca. When is this suppose to happen
My truck is registered in Yavapai county and I have not modified any emissions equipment:angel:
