When I broke mine I upraged to 1480 joints. Wasn't as exensive as I thought it was going to be. 250 for new yokes for the tranfer case and rear side and about 300 to have the shaft upgraded to 1480 end caps
OP, there's a 1480 with straps for sale on CompD in the Dodge section.
I believe GM upgraded to 1480 series in 2007. Seeing that I just replaced old ones yesterday with two new Spicer 1410's, I may upgrade to 1480 next time. Part of the damage is due to negligence on my behalf. I should have checked for wear more frequently. Thank you though.
^^^ The carrier bearing helps reduce drive shaft vibration. My truck is an 07 and it has 1480 u-joint and yoke from the factory (verified by J.E. Reel driveshaft co). Not sure as to when GM upgraded to the 1480. Your truck has either a 1410 or 1480.
Anyone know correct part # for GM 1410 pinion yoke w/seal?
Yoke kit with seal, washer and nut:
12471499 for 35mm diameter u-joint cups or
12471501 for 30mm diameter u-joint cups
I'm not sure if the what the cup diameter is of the 1410 joint
Thats what the GM catalog lists for the 11.5 axle, but the 12471501 is what it lists for LB7 usage
There's also leaking from transfer case rear output shaft. Significant play with slip yoke. How do you know if it's just a bad seal and/or bushing? Should I just replace both?
Going to pick up new yoke part no. (12471501) today at dealer. Will replace tomorrow.
