worth my time?
Burn Down
Sep 14, 2008
7,092
Boise Idaho
You should be fine. The injectors will be easy providing the holes are clean and not carboned up. It may go good enough you can fit the turbo in there as well.
DieselmafiaLLY
Keep Calm and Go Crazy
Apr 6, 2013
1,102
Ontario, Canada
i did an injector a month ago just bc it was out of spec and only took me about 45 min so injectors im fine with its pulling the valve covers and all that other junk I dont like to do the studs:(
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,517
501
Central OH
Head studs on factory gaskets, on an LLY? Ive been told by more than a few top notch guys to not even bother with the studs without putting in the newer style gaskets. Its not that the factory head bolts that stretch like a Ford, its the gasket design that gives out.
DieselmafiaLLY
Apr 6, 2013
1,102
Ontario, Canada
but wont the studs hold the gasket down better
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
just want to get a concensus on what you guys think would be better, studs on stock gaskets or just leave as is
If I were you i'd buy the LLY kit from Henry at COTNP with studs and run her till you see a sign that they finally let go, then tear her down and put the updated grade C gaskets, stud it, get the heads resurfaced and checked for cracks. I wouldn't tear it all down to put studs in with stock gaskets. Might as well do it right the first time :thumb:
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
It was a year in may :thumb: have about 30-40 passes on the current setup. 12s every pass also and still yet to lift a head.
