Why so hot
dman777
Apr 11, 2012
283
Who suggested a snow w/m injection? Lol really. Its not worth its weight in scrap iron. The snow pump is not near enough pump to properly atomize water a 1000hp truck pushing 75 psi of boost. I believe a water injection would be beneficial, but you would need a set up like a lot of puller use that uses a good pump not some atv sprayer pump. Also water injection is just covering up a problem that is still there, its not a fix.
I'm not sure what hp and boost pressure has to do with atomization of water/meth. I thought it has more to do with pump/line pressure and nozzle size/design but what do I know. I think Snow sells multiple pumps with different pressures etc. I'm not saying you need to buy a Snow kit. All I know is from personal experience the Snow MPG Max kit worked great in my application. It was close to a stock truck so I could see why it would help me better than a high hp truck but I'm sure it would help. If your problem is high EGTs and water/meth helps than I would call that fixing it. JMOP
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I hate to say it brian but i believe it to be a combination of stock parts at play. stock exhaust manis/up pipes, stock intercooler, stock cam, stock heads. I dont see changing just one of these parts dramatically dropping EGTs, only a combo of them.
^^^:thumb:
6488 cam, springs and some port and polish work along with manifolds and uppipes and an intercooler would keep you closer to 1600-1800* egt depending on the timing and duration you're running. You'll drop some boost pressure along with drive pressure and make the same if not more powa too! I assume you've already got a solid 3" Y-bridge.
Water meth is a bandaid waiting to pull free at Bri's performance level
Your truck sounds awesome man:hug:
Dirtymaxx03
3,109
^^^:thumb:
How do you know that would get him down to 1600*?
Hot COCOAL
Jun 9, 2012
4,433
I live vicariously through others experiences....:roflmao:
Science works. Read son....;)
He's running 1000hp on stock heads, cam, manifolds/pipes and intercooler:eek:
Who does that? For that alone Brian deserves his own performance badge of accomplishment :)
Given adequate tuning, do you know those parts wouldn't lower the egt's to that extent...? Nice of you to quote the lower # provided:thumb:
Granted, We can't see what his egt's are peaking at, but that's only an approximate 300* drop from what he's running now;) and closer to being in an acceptable egt range for that power level with a big sig.
His drive pressures are high and his exhaust gasses are bottlenecked, regardless of egt's he needs to move them faster and more efficiently, the parts might not keep him out of the 2000* mark but they wouldn't be hanging ther like they are now
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I have a stock Y bridge. :)
Many people did that before me, I don't deserve anything other than to smile.
First thing I will be doing is an intercooler, but that wont be till after the summer. I'll just turn it down and enjoy it like I want to. I don't need to keep hurting the truck because I like going fast, that's childish. I kept saying all I wanted was 10.99 and 850rwhp, and I exceeded those greatly. I think I'll do the easier route and call it a day.
Here's what is stock:
pistons (cut .015 and delipped)
Heads (has Hamilton springs)
Pushrods
cam
manifolds/uppipes
intercooler
trans shafts
Factory lockup, no lockup box
flexplate/balancer
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I don't know if this has been suggested but I had a friend unfortunately he drove a Dodge, but he was fighting high egt's for a long time only to find out his guage was not reading correctly. When it was new it seemed to read normally but suddenly started to read about 400 deg. higher than normal.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,237
379
At Da Beach
I have been able to peg a 1600* pyrometer on our 3.0 truck in less than w seconds every since 2010, I have a Precision 2400hp air to water intercooler all this time and have had 5-6 different turbos. Last year I built equal length 2" primary headers with merge collectors. It still pegs a 1600* guage at the snap of my fingers under load. And I purchased 400% Exergy injectors to reduce pulse width, and my boost is 60-63 psi on current setup with less than that in drive pressure...
I honestly think an intercooler would be the biggest benefit, but then you will be able to add another 100us and make more power and temp will go up again. I think it's the nature of the beast(big single) without water or methanol injection to reduce it. Extra fuel will cool it off also. We were suffering rail pressure, so I had to keep pulse width low and we ran leaner and hotter...
X2, listen to this guy
Either live with the heat or twin it...
PACougar
2,105
41
El Dorado Hills, Ca
Or don't make a 1000hp on a stock motor. The reason others aren't seeing well over 2000* is because they have all of the upgrades that go along with that kind of power. The only exception is in pulling where the rules force you to run extreme fueling to achieve victory.
dman777
Apr 11, 2012
283
Pushrods
cam
manifolds/uppipes
intercooler
trans shafts
flexplate/balancer
That's awesome! Very similar to my truck. How much nitrous did you have to pour to her to get her in the 10s?
SmokeShow
6,818
Lawrenceburg, KY
I just fail to see the problem if it's just on the track or doing a hard pull that it goes so high. I wouldn't do it on long street race because that'd be too high for the lengthy street race but IDT the engine will melt down if it only sees those temps so rarely.
But, for now, you're right to turn it down if it helps you feel more comfy about it. How far do you think you hafta turn it down to see comfortable numbers on the street? Strip?
