Why so hot
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
I would do some up pipes at least, have James make the for you, it is 250 bucks to get everything to make a set of 2 inch. That's all the flanged, bellows and pipe from profab....
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,237
379
At Da Beach
Big single = high EGT's...
Your almost making 1000 rwhp. I wouldn't expect it to be anywhere below 1900. For all you know it is stopping at 2100, you need a gauge capable of reading over 2000 before you go switching parts. Hell, I get my truck up over 1650 and I don't have near the power you do buddy...
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
What's your reasoning behind that? I'm keeping my gauge, it doesn't need to run 1600+ guess ill start looking into manifolds and up pipes again:eek:
dman777
Apr 11, 2012
283
I'm just going to throw this out there cause nobody has mentioned it yet. What about water/meth injection and just use water to cool the EGTs?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I was gonna say w2a but you'd need to make sure it's plumbed water tight. Can't leach on the track. If you do a fogger you better make sure it don't get sucked in the turbo
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
There was a used set of ProFab extreme headers on here but they were designed for twins and didn't have a crushed up-pipe. They come up used fairly often. Same with intercoolers.
dman777
Apr 11, 2012
283
I don't think water is going to cut it. co2 fogger?
Sent from a ditch being dug near you using Tapatalk
But I think it would help. Plus it's not near expensive as some of these manifolds/up pipes or twins. That's what I would try first if everything else on the truck is good and the high EGTs are not caused by something not working correctly. Snow Performance water/meth worked great on my last truck. Leaking was not an issue.
9,905
151
Your engine is trying to breath through a straw.
Time to help the airflow or back off the timing and Pw till you can afford it. Your just going to burn it down otherwise Brian.
Sent from my C6906 using Tapatalk
5,989
I hate to say it brian but i believe it to be a combination of stock parts at play. stock exhaust manis/up pipes, stock intercooler, stock cam, stock heads. I dont see changing just one of these parts dramatically dropping EGTs, only a combo of them.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I have been able to peg a 1600* pyrometer on our 3.0 truck in less than w seconds every since 2010, I have a Precision 2400hp air to water intercooler all this time and have had 5-6 different turbos. Last year I built equal length 2" primary headers with merge collectors. It still pegs a 1600* guage at the snap of my fingers under load. And I purchased 400% Exergy injectors to reduce pulse width, and my boost is 60-63 psi on current setup with less than that in drive pressure...
I honestly think an intercooler would be the biggest benefit, but then you will be able to add another 100us and make more power and temp will go up again. I think it's the nature of the beast(big single) without water or methanol injection to reduce it. Extra fuel will cool it off also. We were suffering rail pressure, so I had to keep pulse width low and we ran leaner and hotter...
Dirtymaxx03
3,109
Brian just get some nice manifolds and up pipes and a good camshaft. I'll bet you a 50lb bag of my finest salt it will be a night and day difference.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
X2, listen to this guy
plowboy_lbz
Farmer
Aug 6, 2013
431
Who suggested a snow w/m injection? Lol really. Its not worth its weight in scrap iron. The snow pump is not near enough pump to properly atomize water a 1000hp truck pushing 75 psi of boost. I believe a water injection would be beneficial, but you would need a set up like a lot of puller use that uses a good pump not some atv sprayer pump. Also water injection is just covering up a problem that is still there, its not a fix.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Understood guys. Easier to turn the truck down than to kick myself in the ass because i burned it up. It will be parked here shortly untill end of summer and ill see what I can do. Intercooler is first on the list. Thank you for all the input.
