Been trying to battle a EGT issue since day 1 of my engine build.
Cruising temps are 100* per 10mph, completely normal.
Friday night my GF took a video of the truck, and just past the 1/8 mile I saw my driver side up pipe connection glowing from the heat. I leave the line at 1100EGT and 25-28psi. The EGT gauge does not stop going up until I maxes out, literally straight down, so maybe 2000*??
I assumed this was because of the drive pressure from the old 75mm with the 83 wheel trying to push it hard, but this turbo (80mm with 87 turbine and 1.10 AR) is doing the same thing. I make 55psi of boost at full tilt, I have pressurized the intercooler system, and fixed the leaks that I found... I have stock intercooler, has been welded. I let 20psi sit in the intercooler when I swapped the 80mm on to check one last time for leaks, found none.
Maybe I am just asking too much out of my setup but I don't like it one bit, I'm going to melt my engine down before it makes it to 10,000 miles. Im trying to drive a 80mm single charger with a loose AR like it's a 66mm, I know it's not going to spool with a crap but I don't need it to. I cruise around no problem with no EGT issue.
The only thing I cannot pressurize is the intake runners from the Y bridge since some of the exhaust/intake valves will still be open no matter where in the rotation the engine is.
This is a problem and I don't know where to start. Certainly the stock intercooler is not helping but I don't feel like throwing $$$ at it to "try" to fix the problem. I'll end up pulling the engine back out this summer.
Going from 100% injectors to 200's and backing the Us down did not seem to change anything. Still is hot enough to make her glow.
Input? After I saw my stuff glowing I am calling it quits until I fix the problem.
