Why does this happen
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Ever since I can remember my truck feels slow and just smokes if I floor it in any gear till I get into o/d. Boost stays in the mid 20s. Infact the only time I really ever see 30+ psi of boost is when its in o/d. But if I down shift manually and floor it, especially if I roll into it, I get good boost low smoke and feels way faster? I have an ally locker so I know its not blowing through an unlocked tc.
Sent from my PC36100 using Tapatalk
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
might be your tq converter or tuning. i know when i was running my ppe on the hot tunes it would do what you described. when i switched to efi it behaved different and bby different i mean the opposite....granted at the top end it felt the same
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I forgot to log this run I'm at the track now ill be sure to record these other runs. Did 13.1 at 101.9 mph with 20s boost and smoked out the whole track.
paint94979
Beer Nazi
Sep 18, 2006
11,715
37
youre truck based on mph is around 475 depending on weight...
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
And it shouldn't be. Thebac has made almost 11 second passes and I'm fighting to hit 12. That's why I could never run good at the track but street racing wax anything around.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Left the track last 2 runs had 102 mph. This was leaving with like 5 psi slow as hell and running half throttle the first 1/8th mile to keep on top of the charger.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Clay city. The kyhorsepower shoot out is tomorrow and I was hopping to run, but doubt I will now. London would probably closer for you I think.
13,716
779
Leave with more boost. I launch at 12 to 15 psi or 2000 to 2200 RPM usually.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
first run I left at 15 and spun so I afterwards it was around 10. Running 285/75/16 on pyos with 35 up front and 30 in the rear. Caltracs adjusted to make contact once boost is built.
13,716
779
When I run my PYOs with 265s at the track, I run about 5 lbs less in front and back. 15 psi launches may be too much depending on your converter, but 5 psi is nowhere near enough. You'll just have to practice to see what your truck likes. I think lowering tire pressure a little will help though. I think you may have something else going on though. I don't have any problems building 30+ psi of boost on my truck with the stock turbo no matter how I launch. I think Simon is right about your tuning. It's being overfueled and is hurting how well the turbo can spool.
