Channel cut on the impeller side. Couldn’t hold the pump from the other side so just put a few shallow drill holes on the gear next to the shaft so my buddy could sink some filler/heat into the shaft and get a bit more meat for a bite.
Cool shot with a thermo imager off his truck we were playing with. Made sure we never got it “hot”. Never saw over 300* at worse. Mainly 250ish
Welding that cast sucked. Acetone, new brush, new scotch lock disc, and even some heat prior from a torch to try to burn junk out and still was a bitch. BUT we got some good weld in there finally. Doesn’t look pretty but I’m more confident in this than my pump that’s in there now lol.
Gear side was the easy side
