What's it going to take to have a 500RWHP 12 sec dmax van?
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
www.larrysperformancepalace.com
I think your on the right track with some tire/wheel combo and a tune. There is an old black 1/2 ton chevy van with a 383 and nos running 10's. Yours should hit 12's easy with some good traction. Just make some initial runs to see where your at with your reaction time and 1/8 mile times. Don't go for broke till you get an idea of what the trans will do first. There is a company that builds a manual shift 4l80e that stands up to 2000hp so, Mike, I am sure can build you one to do as good or even better.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
There was a white express running this last weekend and he was running low 13s.Had bfg's on it too and i heard him spinning off the line pretty good.
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
lotsofmiles if the lift pump runs only on start ups im sure that you could run a constant hot wire to it and put it on a switch so that you could make it run all the time when you wanted:D
13,748
821
I want to get a motor/trans combo out of a van to swap into something. I think it would work pretty good in a light weight rig with the right gearing. 500 HP/800 ft-lbs in a 3000 lb car or compact truck would be a lot of fun.
