Whatcha Got?
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
MAKE -2004 LLY GMC- 074 RED
BODY CC, SB
DRIVELINE- 4X4
ENGINE - SOCAL/MAC RACING
POWER ADDERS- 80MM CHARGER/NX MULTI STAGE
INTAKE- CUSTOM 4"
COOLING- STOCK RAD, H2O to AIR
FUEL-(2) II CP-3's- FASS- II INJECTORS
TRANS - MIKE L 4
TUNING - EFI
EXHAUST - 5" TO MUFF W/MINI STACK
SUSPENSION - 4 LINK-BIG/TIE RODS
WHEELS - WELD
TYRES - TBD
RWHP - 400 (WAG)
RWTQ - 700 (WAG)
BEST 1/4 MILE - PRE MOD 13.4
OTHER MODS - TOO MANY NOW!
FUTURE MOD - SHORT BED DUALLY TUBE FRAME, TWINS, STEEL DIET
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Make: 2006 Chevy
Body: CC/SB
Color: Greystone Matallic
Drive: 4x4
Engine: LBZ, all stock
Trans: Suncoast III/1056 converter, Duramaxtuner Trans tuning
Engine Tuning: EFI Live by Nick @ Duramaxtuner and myself
Intake/Exhaust: S&B/5" magnaflow soon to be straight piped, its too quiet.
Fuel system: TTS Dual lift pumps, Nicktane
Suspension: Bilsteins front, Monroe rear, caltracs, 3inch drop shackels and 3 inch drop keys up front.
Wheels: KMC Hoss 17" black
Tires: Toyo Open Country H/T's 265/75/17
RWHP: 537
RWTQ: 1090
Best 1/4: 13.03 @ 104.6
Best pull: No pulls in AZ :eek:
Other mods: Led Interior. A stick to act as my high idle :D
Future mods: Just the same as every other diesel nut, Build the motor, but not yet :D
6speedduramax
Is Here to Learn!!
Mar 5, 2008
80
Morgantown, WV
Make: 2003 Chevy
Body: RC/LB
Color: Victory Red
Drive: 4x4
Engine: LB7, stock inside
Turbo A5K
Trans: ZF-6 with south bend twin disk
Engine Tuning: EFI Live with DSP5 by Caleb (05_LLY) :yourock:
Intake/Exhaust: AFE Stage 2 intake, 4 inch downpipe, 5" exhaust and stacks
Fuel system: Holley Lift Pump, Modified CP3, Dual CP3 Feed line
Suspension: 2" blocks in rear, T-bars cranked up front
Wheels: 16x8 187 Eagle Alloys
Tires: 315/75/16 Mickey Thompsons
RWHP: ??
RWTQ: ??
Best 1/4: ??
Best pull: Over 400' But was beat in pull off and got 2nd:(
Other mods: Billet Grille, Smoke Cab lights, DVD player, Stewart Warner Gauges
Future mods: Twin Turbos is the current project.
JS2TZU
Dec 3, 2008
287
Kauai Hawaii
Make: 2005 Chevy
Body: CC dually
Drive: 4x4
Engine: LLY, all stock
Trans: Stock
Engine Tuning: Stock
Intake/Exhaust: Modified airbox/ Stock
Fuel system: Stock
Suspension: Stock
Wheels: 16 inch Alcoa
Tires:
RWHP: Unknown
RWTQ: Unknown
Best 1/4: Unknown
Best pull: Unknown
Other mods: Led Running lights, billet grille, PCV reroute, B&W Goosenech hitch
Future mods: MBRP exhaust, S&B intake, PPE programmer
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Make: 2005 Chevy
Body: CC/XLB
Color: White
Drive: 4WD
Engine: LB7 block , LLY crank and heads , LBZ rods , Balanced , ARP head studs
Trans: PPE stg 4 , ATS 5 Star , Suncoast Billet input , Eagle Clutches
Engine Tuning: PPE hot +2
Intake/Exhaust: Custom intake from PPE to cut out egr passage and clock intake tube to clear 2nd fuel line .
Cut and clocked intercooler tubes also . 4" from turbo downpipe to 5" shuttleworth muffler .
Fuel system: PPE duel CP3 pump kit
Suspension: Deaver Springs up front w/ 10 " King 2.5 piggy back shocks . Rear full spring w/ kings in rear also .
Wheels: 22.5 x 8.25 Alcoas
Tires: Toyo 12R / 22.5 hyper radials
RWHP: 425
RWTQ: 932
Best 1/4: 15.90 / 1/4 1.90 60 ft.
Best pull: Still want to try the sled .
Other mods: Custom bed install , Kenwood NAV/DVD , Custom Hitch , Custom Light Bar from Defiant , 4 hella 4000's up front .
Truck built and finished at home . Fresh motor 3 months ago built and installed also .
Future mods: Twin turbo's or a big single .
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Make: 2008 Chevy LMM LTZ
Body: CCSB
Color: White
Drive: 4WD
Engine: LMM, blown :(
Trans: Mike L Suncoast Stage 4 w/ 1057 Converter
Engine Tuning: EFI LIVE McRat Tuning
Intake/Exhaust: S&B Stage 2 Intake with 5" MBRP Muffler/Cat/DPF Delete
Fuel system: Airdog 150
Suspension: Bilstein 5100s with Belltech 3" lowering shackles, SD Tie Rod Sleeves, Cognito Pitman/Idler braces
Wheels: Stock for now
Tires: Toyo 265/70/16 Proxes
RWHP: 500
RWTQ: 1000
Best 1/4: 13.39 @ 102 / 1/4 1.71 60 ft.
Best pull: Dont think sleds are for me.
Other mods: 10K HIDs Lows Highs and Fogs, Billet, Escalade handles, tint, painted plastics
Future mods: Motors coming out of the truck now. Carillo Rods, Forged SoCal Pistons, Stage 1 heads, SoCal Keyed Cam/Crank, PPE Dual CP3, MPI Twin Turbos, Extrude Hone Injectors, ARP Head/Main studs.
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
From the Factory
2004 Cali-Emmisions GMC Sierra 2500 HD ECSB SLT Gray Metallic
Motor: Stock, On Borrowed Time
Not From Factory
Trans: 2nd Suncoast Stage V w/ 6th gear conversion and 1058, Earl's cooler, transfer case brace
Air: Airwerks S64X 1.00 A/R, 5" MCMaster Carr hose intake, F-250 MAF mount, K&N intake with skin
Tuning: Moonshine DSP 5
Fuel: Billet pickup, SD HP Carter lift pump, Cat filter, LBZ CP3
Exhaust: custom 4" turbo-back side exit
Exterior: Pro-Mark graphics, Suncoast Ram Air hood, Toolbox, Road Armor Stealth Bumpers w/ PIAA lights and Warn 12K wireless winch, Rhino Lining, Bushwacker extended flares, AMP steps, Recon smoked cab and tail lights
Lift: Tuff Country 4" with custom Deaver 6" springs and Rancho 9000x shocks, Cognito Front Sway Bar and SS endlinks, SS sleeves, Dual front steering stabilizer, Cognito Braces, Burkhard Traction Bar kit built and modified
Tires/Wheels: H2's and 285 Silent Armors, 18" Dale Jr Chrome Cannons and 33" Toyo M/T's
Other: E-Locker, EGR delete, Banks Intercooler, All Amsoil, Suspension stops, Reese Towbeast, slotted and Cry-od brakes w/ hawk pads and s.s. lines, MA billet pump rub mod, C2 gauges on A-pillar, Bolted motor mount, blow shields, Mag-Hytec pan and diff covers,
Drholliday
286
Gresham, OR
MAKE - CHEV 2006 LBZ - Grey Stone Metallic, ECSB 4x4 LT3
ENGINE - Stock, S&B intake, Shimmed FPRV
TRANS - SC stage IV with 1054 converter.
TUNING - EFI LIVE, tuned by diesel addiction and some of my own tuning.
EXHAUST - Diamond eye downpipe, 5" downpipe back by Flow Pro
SUSPENSION - Stock, torsion bars lowered in the front, spring clamps in the rear.
WHEELS - black racelines
TYRES - Change per truck set up, 285/75-16 Uniroyal Larado's for daily driving.
RWHP - 531
RWTQ - 960
BEST 1/4 MILE - 12.42@106
OTHER MODS - Tie rod sleeves, strait centerlink, T-case brace, AirDog 150 lift pump.
FUTURE MODS - Built Engine, Big VVT turbo, high pressure lift pump.
CrazyDaze
800+HP Build!!
Apr 6, 2009
57
Auburn Hills, MI
MAKE - Chevy
BODY - CC/SB
4X4 OR 4X2 - 4x4
ENGINE - Stock, AFE Stage II Intake, PPE Boost Valve
FUEL- Nicktane Filter Kit with fuel pushed through it by a PPE lift pump
TRANS - Custom built Merchant Stage III with a 1057 Suncoast Converter
TUNING - EFI Live with Nick's Race Tune
EXHAUST - 4" Mystery Exhaust...but it sounds good
SUSPENSION - Big Hog Customs 2" lift
WHEELS - Summer: H2's, Winter: PYO's
TYRES - Summer: Mickey Thompson MTZ 315/70R17, Winter: BFG TA/KO 285/75R16's
RWHP - 506, Dunbar Dyno
RWTQ - 1022, same
BEST 1/4 MILE - [email protected] mph on Winter Wheels and Tires
FUTURE MODS : more air in and out ;)
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
MAKE - Chevy 2007 LBZ SilverBirch
BODY - Crew cab long bed
4X4 OR 4X2 - 4x2
ENGINE - STOCK, EGR Blocked
TRANS - STOCK w/Alli deep pan
TUNING - Banks 6-Gun (EFI LIVE, but no tune loaded yet)
EXHAUST - 4" Banks w/cat delete pipe
SUSPENSION - Stock
WHEELS - MB - summer Stock in winter
TIRES - 265's Mich. ltx m/s
RWHP - 462 (hp&tq were stock tune with H20/meth)
RWTQ - 930
BEST 1/4 MILE - never ran
OTHER MODS - snow mpg max h20/meth, banks intake w/scoop, egr blocked, front receiver hitch, bug shield, vent visors, tonneau cover, diamond plate bed rail covers, 115 gallon in bed fuel tank, over the wheel well tool boxes, 5th wheel & gooseneck, bluetooth stereo w/12 disk mp3 & usb, wilson wireless booster, cb, elec brake, (nov 08 diesel power mag didnt call me the 'tuned traveler' for nothing):D
I'm sure I'm forgeting something
FUTURE MODS - I think its time for shocks, and maybe a new seat
superpro56
Aug 6, 2009
11
Michigan
MAKE - CHEV 2002 LB7 - Forest Green, CCSB 4x4 LS
ENGINE - Stock, K&N filter, Kennedy boost controller
TRANS - Stock
TUNING - EFI LIVE by Duramaxtuner
EXHAUST - 4" downpipe back MBRP w/6" tip
SUSPENSION - Stock
WHEELS - Stock
TYRES - 265/75 R16 Coopers
RWHP - 540
RWTQ - 1033
BEST 1/4 MILE - never been
OTHER MODS - AirDog 150 lift pump, LBZ CP3 w/modded regulator, triple pillar autometer gauges, billet pickup and custom bulkhead fittings
FUTURE MODS - Supercharged, headstuds, caltracs, sleeves and braces, 6" stack
standy
Jun 22, 2009
91
45
Royal Oak, Mi.
Good thread!
MAKE - 2002 Silverado 2500HD
BODY- Extended cab, short bed
4X4 or 2X4- 4X4
ENGINE - Stock, other than at GT4094, S&B intake
TRANS - Suncoast stage III/1057 assembeled by me
TUNING - EFI LIVE by Mark at Danville
EXHAUST - 4" Silverline
SUSPENSION - Stock with tie rod sleeves
WHEELS - stock
TYRES - 265 Toyo Open Country AT
RWHP - approx. 600
RWTQ - approx. 1100
BEST 1/4 MILE - haven't run it yet
OTHER MODS - Airdog 150 lift pump
FUTURE MODS - rods and dual pumps/sticks someday
JMDuramaxLB7
YOU SAID MEMBER!!!
Jun 3, 2007
744
Missouri
Make: 2004 chevrolet
Body: Ec/sb silver birch met.
4x4 4x2: 4x4
Engine: Stock lb7/ swiss cheese airbox/ resanator plugged
Trans: Stock
Tuning: Efi live by nick
Exhaust: 4 inch mbrp turbo back-straight
Suspension: Cooter tierod sleeves/traction bars
Wheels: Stock pyo's w/ nittos winter/h2's dc crushers summer
RWHP: 412
TORQUE: 830
Best 1/4: N/a
Other: Holley blue lift pump and aux-filter/ autometer-boost/pyro on pillar
Future: Tranny
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
MAKE - GMC 2500HD 2006 LBZ
BODY - STD/Long - Fire Red
4X4 OR 4X2 - 4x4
ENGINE - Stock, TTS dual lift pumps, 3" intercooler tubes, all emissions bypassed
TRANS - Suncoast IV / 1057 Mike L. oiler & brace
TUNING - EFI Live by Josh
EXHAUST - 4" straight pipe MBRP W/ downpipe
SUSPENSION - Cognito steering/ Bilstein shocks/ sulastics/ deavers
WHEELS - 20x10 Diamo's for summer and 16x10 Welds for winter
TYRES - 33" toyo mt (summer) 285 Yokohama at-s (winter)
RWHP - around 500
RWTQ - around 850 ???
BEST 1/4 MILE - 12.994 @ 103.28
FUTURE MODS - PAY IT OFF!, built motor, MPI twins, & PPE duals
MFDinosaur
May 20, 2009
14
Northeast Florida
MAKE - Chevy 2500HD 2003 LB7
BODY - CC/SB - Pewter Metallic
4X4
ENGINE - Stock, Banks Bighead
TRANS - Stock & dying a slow painful death
TUNING - EFI Live
EXHAUST - 4" Silverline with Hushpower muffler
SUSPENSION - Cognito braces/ Bilstein shocks/ Belltech 3" drop shackles, front torsion bars cranked down, bump stops cut down
WHEELS - 17" Hummer H2's
TYRES - 285/75 17 Nitto Dura Grapplers
RWHP - 344
RWTQ - ???
BEST 1/4 MILE - No time yet. Need to get to Gainesville
FUTURE MODS - Transmission Upgrade, then more power!!!
mmangels22
Monty Python Rules.
Feb 12, 2009
801
San Jose, CA
MAKE - CHEV 2005 LLY - SILVERBIRCH METALLIC
BODY CC, SB
4X4 OR 4X2 - 4x4
ENGINE - AEM BRUTEFORCE HD INTAKE OTHERWISE STOCK
TRANS - STOCK
TUNING - PPE STANDARD ON LEVEL 2
EXHAUST - STOCK
SUSPENSION - 6 inch Fabtech lift, Bilstein 5125 shocks, Cognito braces and sway bar end links
WHEELS - FRNT/REAR 17x9 Moto metal
TYRES - FRNT/REAR 35x12.5 Toyo Open Country AT
RWHP - I have no idea
RWTQ - I have no idea
BEST 1/4 MILE - never done this either
OTHER MODS - Rhino lining, no other real mods yet
FUTURE MODS
- MBRP exhaust cat back, new rims hopefully. I have no other inclinations yet but the future who nows?
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
MAKE - 1995 GMC SUBURBAN
BODY - SUV
4X4 OR 4X2 - 4x4
ENGINE - 01 LB7
TRANS - 01 ALLISON 1000 5 speed
TUNING - EFILIVE by me
INTAKE - AFE stage 1 with a custom heat deflector
EXHAUST - 4" DIAMOND EYE with a 4" CORSA muffler
SUSPENSION - stock with torsion bars cranked 2 1/2 turns to level it
WHEELS - late model HD alloys
TIRES - 245/75/16 MICHELIN LTX/MS 10 plies
RWHP - ?
RWTQ - ?
BEST 1/4 MILE - ?
OTHER MODS - KENNEDY wear plate in TC, KENNEDY single lift pump, projector headlights, and LED's in pretty much everything else
FUTURE MODS - None as of right now, broke from the conversion
496 BB
Head Thread De-Railer
Feb 20, 2009
697
5
At your girlfriends house
MAKE - 2001 2500HD LT
BODY - Avg/Muscular
4X4 OR 4X2 - 4x2 (only have 2 feet)
ENGINE - 496 BBC 8.1L
TRANNY - When I feel like dressing up
TUNING - EFILIVE
INTAKE - Mouth
EXHAUST - Ass
SUSPENSION - Nike Shocks
WHEELS - Round ones
TIRES - See above
RWHP - 850 (I have a Tornado)
RWTQ - See above
BEST 1/4 MILE - On Main St
OTHER MODS - Lots of em here
FUTURE MODS - Jason2001 cause Randy will be gone
