LB7: What turbo should I get?
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
You will find allot of different opinions, I love big singles but there not for everyone. Do some searching and reading here and don't rush into anything. Although I love my setup I know of other setups I would love to try. It all comes down to your DNA lol!
LWATSON
Jul 30, 2008
2,587
55
Scotland Neck NC
Whats the difference between the 63 mm Billet LB7 Cheetah from fleece and their S363 kit? besides ones a drop in I believe.
I think the Cheetah is a modified stock charger and the S363 is an aftermarket charger. More than likely the 363 will offer more improvement. Don't quote me on this but I think Fleese's Cheetah line is stock appearing chargers with upgraded wheels and maybe more?
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
An aftermarket s300 charger will come with a bigger downpipe and everything you need for install. Chances are it will work just fine with your aftermarket intake. Some of the kits will come with an upgraded intake. If you decided to twin it later on down the road it would tie in nicely with a s400 for a great all around compound setup!
Big Chris
2 Duramaxes> 1 Duramax
Mar 30, 2010
361
46
Rives Junction MI
I've got one of Henry's S366 kits. It's an II silver Bullet 66/74/14 with polished race cover and billet wheel. I'm very happy with it DD and towing. I personally couldn't tolerate a big single. I like being able to spool it at 50 mph without the truck having to downshift and or unlock the converter.
Henry was great to deal with and will set you up right.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
a HTT66mm for a LB7 will include everything needed for install and is right around 2500$. It even includes a driver side dipstick.
JDub
607
Hooper, Utah
With a stock motor, I see no reason to go bigger than either a modified ihi or s300. The Stealth 64 will make 600 with 30% injectors without needing a bunch of install stuff. But swapping to an s300 frame has its advantages.
pizza pig
I Like to Party
Feb 13, 2012
266
CT
I wouldn't think twice about going with the HTT box 66 and install kit. Its the most cost effective, and while it may be a little bit more involved with installation (not really unless you really are an idiot) its a better platform to start with, and is far easier to upgrade when/if the time comes.
yellowchevy
1,928
82
Louisburg, KS for now
If you're going to get an S366, I would go T4 - 66/70/0.91 instead of a T3 - 66/74/14mm.
I had the IIS366 66/74/14mm & it was doggy below 2000 - 2200 rpms with stock injectors. I know it would be better with larger injectors though.
For what I do with my pickup I would have gone a different route from the start. I should have put one of my own souped up turbo's on!! haha
I would get an HTT install kit over a BD one; BD T3 pedestals suck compared to HTT, ATS, etc. Very restrictive.
Yellowchevy
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Yellowchevy
.....But you got my pedestal fixed up right didn't you:D
JDub
607
Hooper, Utah
You could run the gated t3, but I'd suggest the 71mm turbine over the 74mm. Especially knowing that once the 14 cm cast housings are machined out large enough to accept the big 74mm they are prone to cracking.
I just got my HSP s300 install kit this week, will be using an s366/70/.91 with it, I think it will work well with stock fueling for both power and spoolup.
carpenca
Dec 17, 2010
168
I'm really leaning towards the HSP S366 turbo and install kit form Creatures of the Night. good choice??
Cole HSP makes a great product, but we can get you setup with the latest Fleece LB7 S300 kit (Not seen on the website) with a Billet S366 & Upgraded bearings for just over $3000. Its complete from pedestal, remote oil feed, downpipe, and intake adapter. As in something you can install in a few hours if the stock unit is out, and be up and driving when its done.
That said on stock injectors, a 66 is a little much. (Tho I put nearly 60,000 miles on my stock injector LB7 with one) We have a T4 internally Wastegated S362/68 that is an absolute blast to drive!
If you have any questions, just give us a call. 317-286-3573
Caleb
