in looking for a set of tractionbars for my stock height 01 2500hd ext cab sb i hear so many things about not having the right ones and gettin a shitty ride. the truck is my daily driver and i tow with it as well.
i was wondering about this very thing..... i have air bags, but the jerking back and forth needs to stop..... i know i'm over weight with my 40ft toyhauler, but something has to help...
Caltracs ride like Sh!t. No way around it once you take out the rubber bushings and put in the alluminum bushings the ride sucks
i disagree... if you set the springs up right the ride is as good or better then before:coolspot:
while i do need shocks the bouncing is very little... airbags only vary 10psi..i put just enough air in to add support...i try to keep it around 65psi with trailer hooked up and 10psi empty, but i try to let the springs do some work..i'll try to put less air in next time to put a little more load on the springs.... it is the weight jerking back on the springs...Towboat, First off nice trailer..
Second, you have tried a few diff things, from the way I understand it you have airbags in it now and on bumpy roads it gets out of control bouncing.. I might be off but what I am guessing is the trailer is loading the airbags and the shocks can't control the rebound. Might try a diff set of quality shocks that can control the rebound better. (fox or qa1's possibly)
