what traction bars to use
AdaMax
Nov 26, 2010
412
Caldwell , Oh
just make your on set man it would save u some money and it's pretty easy to do get some round tubing and 2 top links form your local farmers supply.....if your going to drag race make them short if your going to pull make them longer figure out what length you wont them cut your top link in half and weld them to the tubing and you have a set of fully adjustable trac-bars we use 2inch tubing it can be 2inch from outside to outside or inside to inside then make some brackets :thumb:
whats the reasoning for longer traction bars for pulling and shorter for drag racing .:confused:
05chevy
1,086
I made my own bars and they r 6' long each and I bought dom tube, tube adapters and the ends and made my own brackets for a tick over $100 and I lost nothing in my ride.
cntry125
Gearhead
Sep 7, 2008
103
Wisconsin
I have Tony B's kit, with 305/65/17 mts on my 2006, i put them on and my ride is back to factory or a little better. i have run blisten silver body shocks all the way around, and keep a little bit of tension on my bars. For bar stock i went down to my local steel shop and had two peices of 1.5 or 1.7d DOM tubing threaded at the ends, so i have like 3 or 4 inches of load. I don't tow much, but i don't think that it would hurt to tow with the bars on, from what ive felt and seen...
jckleewein
Dec 13, 2008
422
Broomfield, Colorado
How long are the bars?
770JOHNNYW
Sep 16, 2009
791
Gainesville ,Ga
i run some real long bars on mine built with tractor links , 2'' schdule 10 tubing, and 2''-1'' excentric reducers...they work great and truck rides and handles better than ever! there almost parrallel with the frame.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I should add, that the longer the bars, the less they actually help traction. You guys can search some of my past threads and trents past threads on the subject.
