What to do?
5,818
Well, had a "explosive" afternoon. :roflmao:
Tested my intercooler system, tank had 80psi in it, turned the regulator up to 10, heard a small leak, to tried to turn it up a bit more, and kinda turned too far, went up to 40psi, as soon as I said "&*$^" the 4" cap 'sploded off the front of the turbo, hit the garage door, and I was already across the street scared out of my mind :roflmao::roflmao:
Tried it again at 30psi and found 4 leaks on the cooler. All where the core meets the end tanks on each end of the cooler.
Top passenger rear of cooler
Top driver
the rigged tester
After sitting at 25psi for 10 minutes, it drops to 17psi. :(
damn, that thing leaks way less than mine :roflmao:
mackthehack
DUH...
Apr 16, 2007
831
What i/c are you going to run? I know one member on here builds them. I will be ordering one from him soon.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Gunna hit the track again Saturday morning with the 22's and see if it will hook better and see if I can beat my best time. hoping for the best. :thumb:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
If I left at 3000 id burn my tires off so fast. I cant leave higher than 2500rpm or truck goes bananas. being 5500 lbs helps and it hurts.
13,713
774
That sucks. Would have been a good pass. Probably 11.2 or low 11.3 ET.
