After a first few passes with my S475, I realized a 1.10AR housing on a 83mm wheel may be too loose for my current HP. I was racing at 9k DA, so that is most of the problem, but im debating pulling the 1.10 off and swapping back to a .90 for AZ. The track here is no higher than 1200ft.
It took 530 rwhp to push my little truck to 110mph, and just wanted to ask if it would be worth while to leave the 1.10 on and see what it does down here, or go back to a .90.
Has 100% DDP's and stock LBZ cp3. Will be getting duals this winter.
I should add, im running a 1058 converter.
