The hp limit on the lb7 crank is......
1hp les than what you had when it broke
It's a crapshoot, good luck:hug: failure isn't all that common, although it does happen, it's happened at all different power levels at all different load demands. I think that has been the conundrum, there has been no constant, no similarity other than breaking near the #1 journal, that seems to be a pretty common failure point, but, it's happened to guys with the cruise set on the highway, hell, it's happened to stock trucks with less than 50k miles....
