What did you do at work today?
motoking_1990
1,957
5
Terre Haute, IN
Made a couple hundred bottle openers out of 20mm C-RAM cases.
Quick question, what exactly do you do for a living I see your always making random stuff? A machinest? It's just different I suppose to me. Usually a machinest does a specific thing.
motoking_1990
1,957
5
Terre Haute, IN
Yessir one month home a year. Jobs pretty easy I'm the senior machinist have a guy under me in the machine shop and 9 welders that are Indian "dot not feather".
Have 2 2.5 axis conversational CNC machines 2 Bridgeport clones and 3 manual Lathes.
Worked on a camera last week that was the only one in the world and was on loan to the military can see you with enough detail to run facial recognition from 35 miles away.. It's amazing what 2.5 million will get you now a days :rofl:
Nvm Corbin was wondering the same thing couple pages back. Very interesting job! Something different everyday.
650
Took the 6/4-6/12 off.. DOT blitz is this week as well.. got a big ol list that needs some chunks taken out of it. Everything from paperwork, shop Cleaning, maintenance on my DD, little thinks that could be better on the dually, pull front dif, finish up 4wd wheel stubs blanks, start atriping the 06lbz that was graciously given to me.
Plus CDL medical exam..brake fluid flush, power steering system flush.. I'm sure I'm missing stuff
motoking_1990
1,957
5
Terre Haute, IN
Sounds like your week is booked!
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,229
374
At Da Beach
Someone gave you an lbz???:)
650
Yeah...more on this? Karma for your bad luck?
Russell cooker offered me the truck last fall just come get it. its a wrecked 2wd 06lbz WT package, minus engine/transmission. Frame is bent, cab/bed is twisted.. ino pretty much shot a rebuild if it...figured I got everything electrical I need to do a repower Into a GMT455 chassis.Definitely worth the Haul back I think the TCM went missing.. but not that worried about it
And thus for a dash/gauges which has everything to keep my DOT legal
http://www.racepak.com/iq3s/
https://youtu.be/1ueMiUoPL_E
~$700 pulse pig tails.... I can do that easy with gauges
elliottw
397
13
ND
Replacing the high pressure lines off the CP4 on a new one because GM forgot to put the pickup 100% together lol
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
Itll buff out
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
The new big boss doesn't like the sound of papers ruffling over the conference phone so I had to make a little getup to elevate the phone system off the table and my boss has a hard on for punisher skulls so I came up with this..
Little plasma little tig little buff.
650
six5creed
1,046
58
N.C.
Been welding on these fingers made from AR400 plate we had cut out with a waterjet that go on a robot. The ole waterjet is neat, here is a piece of aluminum he did for us a while back before we machined it. It's a pretty good finish for 6" thick!
650
Shop improvement tool.. mobileish 6" wide Wilton vice opens up spec is 5.75 gets little wobbly at 7", will handle 1/4-3.5" dia pipe
Need to make couple hangers/tray for 4" grinder and other tools on would be using
One 4wd hub dummy shaft, down one to go.. using the old CV shafts that had slop in them
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Need some caveman engineering on the vice stand, wheels... Brother-in-law finally had some time to weld the plates to attach wheels on my 20 year old stand. Not pretty but does what I need to do and moves out the way easily. I could spend a few dollars and buy a couple cans of paint, maybe...
650
That's nice! Seen you post it couple time.. drill press arbor? Press, HYD press, 210amp welder, oxy/acetone torch. Bigger air compressor are all on the list..
