What compound setup for 1000-1100whp
bcdeutsch731
619
13
41
Illinois
Danville 72mm / Danville Bullseye BMW 483.
I have bigger injectors then what you want to use, but the rest of my engine is about the same as you want to build.
I made over 1100hp
Nickracer9
203
I don't know what id push on the street hp wise but what is a 1000whp like on the street? I really like the idea of the Danville vgt since I could use the piping from my Sdp s475 compounds, but when does a waste gate become necessary and how much drive pressure is too much. Hear the vgt's run high. Thanks everyone!!!
bcdeutsch731
619
13
41
Illinois
I do not run a waste gate. I see 80 psi of boost and 100 psi of drive pressure. I only run the Kodiak manifolds also. I bet could get lower drive pressure if I switched to a header.
Vsouth
137
60% injectors, Danvilee 72mm/gt5533r, dual stock lbz pumps, 2600us. Made 950rwhp. Runs at 820rwhp with a 2200us pulse. Verified on the track about 300 times this year. Towed my 7k trailer all over the country with that setup.:woott:
S Phinney
4,008
Quncy, Fl
I just got mine back together myself. I know what 700 HP is like but now with the triple set it will be much wilder. The triples spool better than my single dis and I am using the same single for the top charger. It is plenty if low end torque. I wouldn't hesitate to tow about anything with it.
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
For a high hp daily driver the only way i would go would be triples or decent sized twins with spray to meet your high hp goal on the dyno and racetrack. But sounds like trips would be best bet for you.
A_T_Ver
416
What are you using for the top charger? I'm going to run triples after i get my motor done. I want it somewhat streetable.
MarkBroviak
DMax Junkie
2,151
549
Danville Indiana
Also are we talking straight dyno queen numbers or track rated power?
bcdeutsch731 is more than track verified as the most powerful and fasted VGT powered truck out there. 9.43@148mph on the tune that dynoed 960hp and it carries the front tires! EMiller and Verlon Southwich both run the 72mm VGT twinned with small injectors and are in the low 11's in crew cab daily driven trucks. I ran mid to high 11's with the 72mm VGT as a single on my stock lbz with 45%inj. Am I missing something here because these are real trucks getting the job done despite what some people think about VGT's capabilities.
Nickracer9
203
So the 72mm has good spool up and reasonable back pressure? Would I want to use the gt4718 or the s483 with it as mentioned above? Thx
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
I think Nick was talking to the OP as in if he wants a dyno queen or track 1100hp
MarkBroviak
DMax Junkie
2,151
549
Danville Indiana
For a 2.8" turbo it is stock like compared to driving an S472. Drive pressures are in check with this turbo so that is not a worry! The C10 makes 80psi boost and roughly 100psi drive in his twin setup.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I plan to have mark work his magic on my 4094 and turn it into a vgt72, i plan to run a gtx4718 and dual cp3 with 80-100% over injectors from exergy. I am looking to run a solid 650-700 on the street with track potential of 1000whp on that set up with fuel only, i have been reassured that this is easily attainable with a set up like this. Of course this is on a built engine, and i will drop a1/2 to 1 point of cr? But i haven't got that far yet into the plan.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
100 psi is really good! How fast does it spool? Im assuming really quick being a VGT,Im just curious as to what made the decision to go VGT?
I know this is a different animal but my stock lly had close to 3:1 DP on stock tuning, but this was at lower RPM not at peak is this a case with the bigger VGTs?
anywho its still impressive what you have done:thumb:
Oh and to the OP......IMO you dont run 1000hp on the street, you just break parts and cant keep it straight, 4X4 is even pointless i would break all 4 tires loose
