LMM: Well it finallly blew, and Now it Runs!
slowlmm
Mar 2, 2008
2,582
46
so cal
Truck fired right up first try. now the only problem is the masive oil leak comeing from the rer some where :( frick if its not one thing its another well at least it started
slowlmm
Mar 2, 2008
2,582
46
so cal
could be i dont think so thoe. we looked pretty good today down in tht area and couldent see any thing wet and stuck some swabs and nothing wet came out. i thinkin its the upper pan where it bolts to the bellhouseing but will look harder at every thing tomarow on a lift. to make sure where its comeing from. a few pics from yesterday
ripmf666
15,123
14
47
Wentzville Mo
After you had the rear adapter plate on and cast oil pan did you install the bolts from inside the pan to the adapter before installing the lower black oil pan.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Towed Tommy's truck to Mike L's today since another leak spouted last night. Luckily Mike happened to have the tranny cooler line in stock:D, we swapped it out quick. Thanks Mike:hug:
Still have the engine oil leak though.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Just looked it up the oil pumps were Leftys in 01's -08's nothing has changed.
Would a discontinued part be listed?
we are on our way to take a look at the leak.
If it's the return pipe like i as well as others are thinking.... tommy is getting a different turbo !!!!! Come on tommy, it's only money, it'll grow back !
DO IT:D
Or fix the return line or rerought it
slowlmm
Mar 2, 2008
2,582
46
so cal
x2 thanks again mike. and jason again. greg you where no help :D but will be mon when its your problem i meen privalage to work on it :D and get it fixed :D oh yea dont forget to fix the squeal )
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Keep in mind there are two lengths for the drain pipe: LB7 (short), LLY+ (long). There is only a 1/2" difference, and only by side by side comparision can you tell. You CAN force an LB7 to fit an LLY, and vice versa, but almost always it will leak. Maybe not the day you install, but it will.
Aftermarket LB7-based chargers (A5000, HTT, BD, etc) will require an LB7 (short) distance even if put on a LLY+
slowlmm
Mar 2, 2008
2,582
46
so cal
I got this last one from you:) since braden never sent mine back. I remeber you showing me the diffrences betweeen the two thoe and it wasent much. for sure and could be easly mixed up for sure
NelsonDiesel
Formerly StewieTuned
May 8, 2008
896
41
Buena Park, CA
www.NelsonDiesel.com
i am over joyed to have the opportunity to work on your truck !
reaching my hand on top of the bellhousing i can feel oil. I will clean it all off and throw some dye in there and go from there.....
That trans line was a huge leak so i'm glad thats fixed and we can get this oil leak fixed and you back on the road again !
If i take the turbo off and you don't have a larger one to put in it's place i'm gonna be upset ! :D :D :D
PPE is right down the street..... :hello:
