LMM: Well it finallly blew, and Now it Runs!
ripmf666
15,123
14
47
Wentzville Mo
Some pics from my phone.
Put the crank back in with the new bearings, and 5 pistons. Called it a dat after that
Looks good, In your first pic you need to remove the crank sensor reluctor assembly, And install the cam put that in time and install the oil pump.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Some more pics, Tommy has been making some progress during the day:D
slowlmm
Mar 2, 2008
2,582
46
so cal
Pop quiz can any one point out whats missing on the front of the motor in pic 3-4 hint its not the oil pump.
slowlmm
Mar 2, 2008
2,582
46
so cal
plug your mouth :rofl: ok jacko there was suposed to be no inside info on this one :D yep little freeze plug missig right where the oil pump goes time to take the fron cover back off :eek: oh well better to see it now then after the driveways full of oil
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Time to update your avatar;)
ripmf666
15,123
14
47
Wentzville Mo
Come on there only .25 cents #94150231
you did not forget #94011695 o ring right side cover 1.63
or #94011609 o ring left side front cover 2.19
:hug:
slowlmm
Mar 2, 2008
2,582
46
so cal
:hug:
Are you talking about the oil pump and relif valve o ring? i put both of those in new as well. thanks for posting tose part # for the plugs:hug: is that a dealer only item ? wish i could find some tomarow
slowlmm
Mar 2, 2008
2,582
46
so cal
One more day of work and it shuould be all finsihed up tomarow ready to go back in the truck.. wireing harness fuel rail oil pan and rear motor plate thts about all thts left :D Thanks johhny for coming and adjusting the valves and showing me how. :)
