Well I guess it's time
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Machine shop I used to clean, pressure test, mag, shave and do a valve job on did the heads. The shop im using to assemble the shortblock found this on Friday when the heads went on.
Was told the rips in the seals was from lack of lubrication upon assembly. :eek:
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Thank god they caught it now before it was in the truck.Pretty sad when you have what you consider to be a professional shop do some kind of motor work and you wind up with something a 5th grader put together.I'm afraid I would have took it to be done correctly and not looked at that myself.
5,931
Same here. if i would have caught it, it would have been out of dumb luck.
brian, do you need seals? im 99% sure i have a set at the house i didnt use
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
steve, its a 7800lbs lifted CC/LB on 37s. i shouldnt be winning to begin with!!! :roflmao:
Ok so you weigh 1000lbs more(when im fully stripped) :woott: big deal.
aaaaand you have like 200 more wheelhorse than I do...
37s? Thirtyshmevins:D... ADeso runs healthy 11s on big meats and a lift :poke:
5,931
According to the dyno I only have 500hp so I dunno where that other 200 is comin from. And ***** Andrew bitched out and went 35s
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Both of you ever roll across the same scale? I'm betting James is more then 1000 heavier.
5,931
Nope, mine was a CAT scale down off the I8 with a trailer on the back so its not exact numbers but its damn close. just my spare and tools in my tool box weight 265 lbs :D
