well... i finally get to
624
from what i have seen with other stuff that has left his shop i agree.
talked to him today.. the block i have gotten had a piston split in it.. and i bought i knowing that. i didnt have the tool to measure he told me is was .009" deep :eek: so .020" goes the block and adds ~1500 to parts cost :(
def have a solid short block good to about 750-800 reliably
624
thought i would post some pics of what i have been doing while waiting.. for my short block to get done
.316 wall pipe 2" ID 2.625" OD weighs 8lb a foot
14k towbar/ traction bars
75 K25 4WD 350/350/203 with 285/75R16 cooper ATRs pull the 350 out put my 305 in, fixed the transmison housing (broke the tail due to an unbalanced drive shaft and bassicly non exceitant tranny montts) u-jionts on the front drive shaft front axle need the u-joints installed and axle seals. stock lift
the plan is to flat tow the 75 back behind my 02. the female couple is a 2 5/16 rated for 14000#GVW and 2100# tongue load. i will get better pic tomorrow with my camera
sema has most likely screwed me:(
624
guy is doing the machine work or what ever is needed so that i can assemble it. bore it .020 over, balancing and resurfacing the deck.
he also said i could barrow the main seal installer and oil primmer.
624
it doesnt take two weeks to bore, deck surface and balance a short block........
last i heard it was a the machine shop that was 11/4 i drop it off 11/27...:(
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Be paitent my guy took 3 months:eek:
Adam did you have to go the 20 over?
I have a feeling your motor is going to be stout,need anything metric? remember your Canadian friend;):hug:
624
.020 is .508mm if i did the conversion right
no offense simon.. but you my northern buddy have more hoops to jump through in getting parts then i do.
one of my messages got through to guy today. he called me back said they use mallory on the front and back (lbz crank with LB7 externals) and it will be ready for pick-up monday the 10th. had to drop the main studs and head studs and run stockers :(
so the plan i spick up the block and 1/2 a steer that got offered to me. go back to moorpark assemble and the truck should bt runnign some time tuesday after noon :D
624
It will be worth the wait when you get it back:D
that maybe true...
but when i got some one's word it would be ready for pickup 10-31-08 and it is still not ready. irrtates me. :(
i dont think it guy's intention to have this hapen and believe he will take care of me.
it costing both of us more money then it should. me sitting here waitng for it and guy money as well for the rework that need to get done due to not being done right the first time.
guy said he will call sometime between 0830-0930 and let me know..
slowlmm
Mar 2, 2008
2,582
46
so cal
that maybe true...
:rolleyes:
well you could of also taken to some crap shop tht could of half ass balnced it and gave it back to you. with out you knowing. i know the time down sucks but to have it done right is more important. even if you expected it earlyer. i have not seen one person say on any build thread any where tht they got wht they wanted whn they expected. its just part of building a motor.
624
:rolleyes:
had a long reply typed up and the automatice long erased it :(
point taken tommy.
bassicly what it come down to someone(s) droped the ball and made guy look bad poiting him between a rock and a hard place on this :(
as i understand it what couldnt get done right in 2 weeks is gettign done in less then 24 hours.
this is a basic build nothing fancy. line hone, bore "n honed, surfaced, balanced. lot less then what you got done tommy
624
i have had to pull head studs, and hte HD bearing from the build
uses some 200.00 in malory to get the darn thing balanced couldnt get a internal balnacer or flex plate for the lbz crank :(
block is now get bored over .040 from the .020 orginally... only thing nice about this is it will now be a 410.6ci motor
slowlmm
Mar 2, 2008
2,582
46
so cal
would it of been better to get a diffrent crank ? so are they still working in it or is it done now ?
slowlmm
Mar 2, 2008
2,582
46
so cal
they are still working on the block.
crank is balanced
lb7/lly are externally balanced vs lbz and newer are internally balanced. that was the main hick-up
hmm i was pretty sure mine was externally balanced as well :confused: How come you had to go 40 over ? is tht wht it needed or did you just want the extra air ?
