Weight Transfer 4wd launch
jnieberlein
Secret Squirrel Diesel
Aug 17, 2009
689
West By God
Ideas to help the front end from unloading? Suggestions for Qa1 single adjustable settings? Rear leaf caltrac adjustments?
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
I've played with my caltracs just a little bit and they make alot more of a difference then people think. I always thought oh its in 4x4 it's gonna go no matter what. Moving a hole on mine dropped my 60 like almost 2 tenths.
prostreeter600
Street rodder
Jul 18, 2010
894
7
Dallas Tx
I agree with Harbin, adjust your shocks to their tightest setting to where it will tie down your front end . If you have adjustable rear shocks I would do the same there, that way any weight transfer that goes to the rear can go to putting pressure down on the rear tires instead of getting eaten up in suspension travel .
Josh154
1,220
85
Sioux Falls SD
Harbin what qa1s are you running on your lmm and what lowering mods do you have? I want to make some suspension changes this winter and get my 60's down some more.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Place your rear shocks more vertical and both on the same side of the axle. It was a game changer for launching on my truck.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Anyone ever played around with limit straps or even hydraulic bumpstops mounted upside down to keep the front end forced down
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
Chains worked for me. Alot cheaper than shocks. But a good setup is always better than a getto setup. Also, clamping the rear leaf "seemed" to help with squat.
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
I'm not looking for ideas to improve I have my setup dialed in well. I'm talking specifically about the two things I mentioned. Has anyone tried either one and what were the results.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
Had local guy try some limiting straps about 2 years ago, still running oem shocks, the truck would pop up so fast hit the straps very hard, and when that happened it would actually try and yank the front tires for a split second when it hit the end of the straps so his front tires would spin causing to load and bind the drivetrain to the rear tires and it would hop violently out of the hole. He finally threw the straps away and went with rancho 9000s and spring clamps after he tore the rear driveline up.
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
Damn thats rough. The issue there is slack in the strap, I'm thinking more like a sled puller here. Like they use rear stops im thinking put the straps on at the track and make it so they have zero slack
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
Yes he had to much slack for sure. That could possibly work the way your saying though. Be interesting to see the results on that.
