Just wanted to revisit this topic for a bit:
Currently I am sprayting before the IC w/ a 720cc injector. And I am spraying after the IC with a 280-380cc injector (right around there). I tried to run a smaller injector on one of them but my pump hits some kind of high pressure shut off and it causes it to cycle on/off real fast. Something weird going on with it... any smaller nozzles than this and it isn't happy. (150psi coolingmist pump)
Anyway,
What I'm getting at is running my biggest nozzle before the IC. I read on a few injection company sites this isn't recommended. Some mentioned pooling but I'm not worried about that because I start spraying at ~20psi
But they also mentioned some other possible issues:
http://www.alcoholinjectionsystems.com/a40/Where-Do-I-Position-My-Water-Methanol-Injection-Nozzles/article_info.html
Really like to hear what you guys think about all that?
Maybe switch and run my smaller jet before the IC?
Anyway,
http://www.alcohol-injection.com/articles/where-to-locate-your-alcohol-water-injection-nozzle-2/2 Pre-Intercooler
Pre-intercooler seems like a sensible nozzle location but, the thing to think about is if the air entering the IC is pre-cooled, the ability of the intercooler is because the temp difference is lesser. It is also possible for the fine water/alcohol mist to collect in the bottom of your intercooler core. We don't recommend this location either. The other problem is that there's a possibility that the hot air from the turbo might unnecessarily vaporize the water and take up some of the volume built up by the turbo that was supposed to be for the charge. Pre-IC does work for some track cars such as road racing that operate at a more constant higher RPM. For the daily driver, weekend racer, the pre-intercooler location should not be considered.
2. Pre-Intercooler Injection
While pre-intercooler injection may at first seem like a logical approach. Thereby, combining the effects of water methanol injection within the air-to-air intercooler for an increased synergistic effect. It is not so. Matter of fact, it's the opposite. The cooling effects and benefits offered by the water methanol injection are less when injected here then in all other locations. Further, more other issues arise such as puddling which can form in the bottom of the intercooler. Additionally, pour atomization will occur as the fluid will accumulate in the individual air to air intercooler core walls of the intercooler forming larger droplets which will eventually break away resulting in pour atomization. We do not recommend pre-intercooler injection.
