Yep closer to the intake the better watched a lb7 pick up 70-90 rwhp on a superdlow dyno with the 60/40 mix
I get timing rattle when I run over 40% meth with my hot tune
So true. Gayest job I have had to do yet was pulling the stocker out!
QUOTE]
exactly what was tough?
Obvious that you haven't pulled one out in awhile.
I think it has to do with the old joke: "What's long and hard on a Canuck?"
A: 4th grade.
Ouch.
What size nozzle would you guys suggest?? I'm making around 28psi at best.... I got a screaming deal on this kit used, came with 4 injectors... 2 small and 2 larger ones. I'm only seeing 50 to mabe 100 degree drops in egts. It's not going through the gallon tank very fast so I'm assuming it wouldn't hurt to buy another larger nozzle....
Does the water puddle up in the IC?
Thanks guys, that gives me some ballpark on where to start (I have no idea what size nozzle I'm using now, but I think it's too small).
What about spraying pre-IC where the charge is really hot? Does the water puddle up in the IC? just curious because I could add a second jet MUCH easier to the pre-IC pipe I made since it's a two piece pipe.
