Ok... picked up a Coolingmist stage 1 kit.
I have a tank (3/4 gallon or maybe 1 gal) I am only interested in running the system at higher boost (probably set it around 18-20 to come on) Just for cooling off WOT stuff... looking to run pure water or close to it.
I have done quite a bit of reading, I have seen arguments both ways. Sounds like before the turbo does a better job at cooling etc. But also you run risk of some turbine damage (possibly?)....
What are you guys running? I will stuff this thing in the truck tomorrow after work.
Thanks for the thoughts on this!
