Want the biggest single cp3 and still be streetable.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
So ive read. Not to jack your thread, if f two stock pumps are the best for streetable high horse app's, how far will a single stock cp3 take you? I have been told you can squeeze almost 700hp off a stock single cp3, that was only on a dyno tho, when is the stock unit going to be "not enough"
Dirtymaxx03
3,109
you can get a 100 over single pump and still DD it. But, chances are it will blow up in 5,000 miles
Dirtymaxx03
3,109
600ish hp area. All depends on how many miles it has on it and how long its been pushing more fuel than it was intended to. My cp3 used to hold close to perfect rail pressure when i first got the new tunes for my s472. Now, its 3,000 psi low in the rails
DaveB
Sep 6, 2009
409
Northeast Indiana
Mark at Danville has had his Exergy stroker pump for quite a while now and it's still going strong. Have to call him for more details...
Hot COCOAL
Jun 9, 2012
4,433
Ok, thanks dirtymax. I agree with you justind, 5000mi would be less that 2 mo for me, not what i would consider a DD modification. Now equate that into 1/4 mi passes and thats pretty good!
DetailsUnlimited
1,264
Benton, Ar
If I had twins(more air) I could use what I had but that's not in the budget. WD and floor it pumps seem to be the most reliable. I've heard of one WD fail and none of Johns. Correct me please if I'm wrong.
paint94979
Beer Nazi
Sep 18, 2006
11,715
I am a victim of a grenaded modded pump... Imho if you want reliability you will want 2 stock pumps.
