Waglers New Budget Rods
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Yeah, with a set of Carrillos in your hands you can tell they are machined everywhere just like a billet rod - but you will have a hard time seeing any milling marks on them. Some other billets you see a lot of the machining marks on - they almost look glass beaded and not shot peened.
Shot peened according to the website.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Who cares what they look like as long as they don't bend
I didn't say I cared about the visible machine marks, or even who's rods I was talking about. I was just explaining to WolfLLY that Carrillos were fully machined.
I know Carrillos are, I was talking about some billet rods I have seen looking like that are not.
diesel-max
Haisley Never heard of her
Oct 20, 2011
172
IN
I wonder how close the weights are since they are not fully finished machined? Or would they still be pretty close?
It's been hit and miss but out of the last 3 set's done, 1 set balanced 'ok'
the 2nd set was a little more difficult and sadly my personal set being balanced with my compstar right now had one that is 30+ grams heavier then the rest and is being one of the worst to balance.
Granted you get what you pay for I'm sure that the extra money spent on the comp rods would make up for the money spent at balance.
I personally think these rods will hold 1000+hp. and Wagler didn't seem to have a lot of doubts with that. Although being shown as a 800hp rod. The compstar is rated at the 800hp level but seems to be a lot better than the factory crank shaft. I don't for see Callies putting out a product that would be inferior to the factory that has held over 1000hp builds with the common breaking here and there in everyday trucks not even from power.
I guess I will see both their strengths as soon as mine is finished at the machine shop with balance.
wagler lb7 deliped and valve relief pistons
callies compstar
wagler street rods
150% overs with dual pumps
modified vgt and a 485 5blade twins
should be a good test.
S Phinney
4,008
Quncy, Fl
callies compstar
wagler street rods
Your pistons are going to give up. I would wager you don’t get 10,000 miles on it before a failure. The compounds wreak havoc on cast pistons other than the Fingers oval bowl design. I’m just telling you from experience if you don’t won’t to pull it and rebuild in the near future re-examine your build.
diesel-max
Oct 20, 2011
172
IN
That would be a great sales pitch if you worked for an aftermarket piston manufacturer, but I think I’ll stick with this budget build and years of seeing trucks still running fine with stock Deliped lb7 pistons making mild to wild 1500hp and are still running. Good thing wagler deliped and cut the valve reliefs in them for me as well... I’ll take my “gamble” ;)
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
You have 1500 Horsepower engines with de-lipped LB7 pistons?? Wow. You must have at least a dozen lucky rabbits foots.
I’m not saying you don’t. But dam that’s impressive, and quite the gamble.
S Phinney
4,008
Quncy, Fl
Do me a favor then and keep up with how many miles before you crack one.
diesel-max
Oct 20, 2011
172
IN
For example:
Earlier this year Nyes automotive’s dyno
Lb7 deliped
Wagler rods
Wagler lbz ported stock heads
S&s 200s
485 5blade single
24* 2100uS
1444hp 2049ft lbs
1750*egts
Ran all year tore apart looks fine. Going back together for another season.
S Phinney
4,008
Quncy, Fl
You are talking single turbo. When you run compounds they just won’t hold up as well from my experiences.
diesel-max
Oct 20, 2011
172
IN
lolol. So turbos dictate piston life now? I guess I learn new things everyday.
I guess I’m just not very experienced in the diesel performance field. :D
S Phinney
4,008
Quncy, Fl
They dictate boost number which effects cylinder pressures and effect torque numbers as well. It really doesn’t matter to me what you do since it’s not my money. I offered what I thought was friendly advice.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Yep turbos dictate pistons like they dictate rods. Where the power hits and fueling and spoil and pulse width. Everything. At least that’s what I understand from my readings
Fingers
Village Idiot
1,715
86
White Oak, PA
There is just an amazing amount of difference between popping a couple good numbers on the Dyno and laying it down frequently on the street or strip.
But, everyone to their own. Your money, your party. All of the aftermarket manufacturers exist and prosper from lessons learned.
The thrill of making power with inadequate parts is akin to Russian roulette. The thrill lasts until the hammer hits the primer.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I like this^^^^^ I personally prefer the peace of mind of jumping in my truck knowing it’s built right rather then being on the ragged edge all the time.
Yngdmax92
962
Fellas, just let it roll. No matter how you do anything it'll be a learning experience. No sense in arguing over something we already know. You can have the perfect build and your crank can still fail at any time lol..... Just saying.
